Updating my headlight.
Discussion in 'XJ Modifications' started by Samuel Zacharias, Jul 5, 2018.
  1. Samuel Zacharias
    Samuel Zacharias New Member
    Colorado
    Hello, I've got my first 650secca here recently. The old stock headlight is pretty beat up. I'm looking to update it with a LED set up. I'm pretty sure I would have to downgrade to a 7in and then get a whole new mounting kit as well. What have you all done with yours? Any recommendations??
  2. k-moe
    A new bulb usually does the trick.
    Pics of the headlight please. They are getting harder to find, and are worth saving if possible.
    The Seca 650 doesn't have anything special to it electrically, so you can do an LED conversion just about any way that you'd like to.
    LED headlight site:xjbikes.com
  3. Samuel Zacharias
    Colorado
    Well I've found the original housing is bigger then the 7in led so I may have to buy an entirely new bucket.
    The old bucket is too beat up to still use
  4. XJ550H
    get a standard 7 inch bucket that is from any other xj with a round headlight you will need spacers to mount in the current ears
  5. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Appologies for trampling over your thread, but has anyone got experience of fitting h4 led lamps instead of the halogens? I'm probably going to be happy with the light, but cutting 5A from the alternator load has to be worth it?
  6. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    I tried lots of led replacements in a, few vehicles including xj. In my experience none of them looked right, or the high low was not right. I went with a sliver star halogen ultimately. If you find a bulb that's a good drop in please let us know.
    Chitwood likes this.
  7. Fuller56
    Fuller56 Well-Known Member
    When I got my Seca 650 many years ago it had a beat up, ugly and poorly working square headlight. It was replaced as soon as possible with the lens and bucket from a first generation Suzuki SV650. It works well, fit easily and is still there. I would prefer to go back to the factory set up and have acquired a nice lens but the bucket was rusted out. Don't scrap your bucket! Another thought for the 7 inch LED idea is to find a Harley DayMaker set. Not going to be cheap but is 7 inch and reported to be awesome light output. Good luck.
  8. k-moe
    You had a Seca 750. It and the Maxim 750 are the only XJs that had square headlights.
  9. fasterdammit
    fasterdammit New Member
    Syracuse, NY
    Be mindful of the socket and the wiring; I put an H4 in my Ducati Monster's bucket but an extended night ride w/ the hi beam on melted part of the harness. Wound up replacing the bulb socket with an automotive high-temp-rated one and haven't had a problem since.
  10. Fuller56
    "You had a Seca 750. It and the Maxim 750 are the only XJs that had square headlights. "
    Nope, sorry, you are incorrect. I have a Seca 650 and when I got it the headlight had been replaced with the awful, incorrect, poorly and improperly fitting square headlight.
  11. k-moe
    Someone fitting different headlight does not make me incorrect about how Yamaha built the machine. Your post didn't mention that the hedlight had been changed, just that it had a square one.
  12. XJ550H
    H4 is a style bulb what wattage was the bulb?
  13. chacal
    XJ900's have rectangular headlights........
  14. fasterdammit
    Syracuse, NY
    That's a good question. It was a while ago now; I'll have to take a look & get back to you.
  15. k-moe
    Bu who has ever actually seen an XJ900 in the wild? Those things are rare ;)
  16. Minimutly
    West Wales, uk
    Mmm, not so rare in the Uk?
  17. chacal
    I know Dave hasn't...........
  18. k-moe
    You missed the joke.
    And yes, not so rare outside of the U.S.
