maxim 750 engine strip
Discussion in 'XJ Technical Chat' started by sydmac, May 7, 2019.
  1. sydmac
    sydmac New Member
    ireland
    Hi all,have my maxim 750 stripped for work, can someone tell me is there supposed to be plastic type tubes over the front crankcase engine studs?? can these be sourced and is their job to stop oil passing through the studs? Thanks.
  2. Toomanybikes
    Tsawwassen bc
    They fall apart but have nothing to do with stopping oil. I believe they are there for 2 reasons. Dampen noise and prevent corrosion.
  3. k-moe
    @chacal has replacement sleeves, and replacement studs.
  4. sydmac
    sydmac New Member
    ireland
    Thanks, you think I should replace so.
  5. Toomanybikes
    Tsawwassen bc
    Not imho
  6. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    you can use heat-shrink tubing over the studs, does a great job
    stu
    Chitwood and Polock like this.
