XJ 750 squealing
Discussion in 'XJ Technical Chat' started by EvilMonkie, May 26, 2019.
  1. EvilMonkie
    EvilMonkie New Member
    Calgary, AB
    Hello,
    I have an xj750 and recently I took it back out for the first time in a couple months (I broke my arm). And it has developed the squeal only when moving whether the clutch is engaged or not.
    It sounds like it's coming from the front end, but I can't be sure. Any suggestions what to do or where to start?
    J
  2. k-moe
    When was the last time the speedometer cable was lubed?
  3. EvilMonkie
    Calgary, AB
    I don't know, how do I do that?
  4. XJ550H
    disconnect the cable pull iner cable out and lube it up if you also disconnect the bottom cable you can spray lube down the outer cable.
    or just put a baggie with the corner cut out nad taped to the cable put your lube in the bag and let gravity do it thing
  5. k-moe
    Use the right kind of lube though ;)
    EvilMonkie likes this.
  6. EvilMonkie
    Calgary, AB
    Thank you. That completely stopped the sound.
    Only problem is the needle started to bounce and now it's broken off. How do I replace that? And stop the bouncing?
  7. XJ550H
    if part of needle is still there glue a tooth pick to it and paint it red.
    you need to clean and lube speedo.
    there is a thread on it
  8. EvilMonkie
    Calgary, AB
    Thank you everyone for your help. Your advice helped me get things back up and running.
    It's my first bike and I'm just learning how to take care of it.
