400 mile Round Trip With a Sidecar Attached MPG
Discussion in 'Reviews - Service, Online, Retail Shop' started by Colin Marshall, Jun 26, 2021.
  1. Colin Marshall
    Colin Marshall New Member
    U.K
    So I Rode Up To See My Dad, should of been a 250 mile round trip, but i got lost in Wales, Up and Down a Few Mountains, and came home the Scenic Route, Had a look a my Petrol Receipts, and i was quite shocked, ok i was plodding along at 50mph most the way on A Roads (A36, A350) and 60/70mph on the Motorway (M4) had a little bit of side wide and when it hits the shopping trolley sometimes is a bit ass clenching :) 4/5000 rpm most the way, only grabbing a handfull of RPM a few times on the twistys, yeah taking it easy and letting the old girl canter, just checked my petrol receipts, 70 miles and 6.36 ltrs in the tank works out about 50 mpg, best was 55.74 mpg ... yeah i was a bit shocked, wondering if putting XJR 1200 silencer's on her has mad a difference, or was it just purring the engine all the way ?? Yep You Heard Right :) XJR 1200 cans, had to have a sleeve made and swathed out to 50mm
    Franz likes this.
  2. Franz
    Franz Well-Known Member
    Scotland UK.
    Do you have the original Yamaha header pipes fitted?
  3. Colin Marshall
    U.K
    Not Sure, The Header pipes might be, but they go into a splitter like the pic, no balance pipe
  4. Colin Marshall
    U.K
  5. Franz
    Scotland UK.
    I have Jama header pipes. Need to check if the silencers will fit.
  6. Colin Marshall
    U.K
    You'l Need an Adaptor like 38mm to 50mm, the XJR pipes had a removable solid sheath inside so 50 mm worked , if i cut the the 2 into one splitter down a few inches or the Adaptor slid over the splitter freely ( kind of has a bump stop ridge in the middle ) the pipes would marry up with the original hanging points on the footrest
