81 750RH secca
Discussion in 'XJ Technical Chat' started by Dvanmatre, May 3, 2022.
  1. Dvanmatre
    Dvanmatre New Member
    Boat
    Recently got an 81 750 RH secca. Top end was in pieces, was going through the service manual, and it mentions cam bearings in the engine overhauling section. i cant find any information on these bearings. Help is needed.
  2. Franz
    Franz Well-Known Member
    Scotland UK.
    Cam bearings are part of the cylinder head.
  3. Dvanmatre
    Boat
    Are they replaceable or machined into the head?
  4. Franz
    Scotland UK.
    Machined into the head. Don't know if a machine shop can repair the head.
  5. Dvanmatre
    Boat
    Much appreciated. Im sure its possible other wise they would have came up with an insert for it.
  6. Franz
    Scotland UK.
    Yes it's all the one piece of aluminium machined at the factory.
  7. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Don't kid yourself. Anything's possible, but it just aint worth it.
    If the bearings are damaged you'd need to machine all the lower bearing lands, and also all the cap lands (where they fit together). Then line bore and hone it all as one. Probably $500 to $1000, then re lap the valves and reshim them, plus gaskets etc. If it was rare and unique, or in your own workshop, in your own time, then maybe you would, but otherwise, no.
