It broke just from pushing it to start it
Discussion in 'XJ Technical Chat' started by Litaos, Oct 30, 2022.
  1. Litaos
    Litaos New Member
    Argentina
    Hello friends! I had to push the bike because the starter relay broke.
    After 50 meters, the motor made a noise and stopped. When I start it makes a broken noise.
    the timing chain is well synchronized, the oil pump works well, when I put the spark plugs it makes a strange noise. I don't know where to start. The same thing happened to someone? Thank you!
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    So with no spark plugs it sounds smooth?
    Turn it over by hand using the reluctor square nut without the plugs.
    Let's see if you feel/hear anything when doing that.
    I think it should be anti clockwise when looking at the left hand side of the engine.
    Hopefully you are talking about an XJ of some kind.
    Litaos likes this.
  3. Litaos
    Litaos New Member
    Argentina
    Hello!
    - no spark plugs no noise
    - With spark plugs and turning by hand does not make noise
    - With the start and at good speed it makes an internal noise.
    - It is not the timing chain because it is synchronized
    - Oil pump chain works fine.
    - I have uncertainty.
    Will I have to open the engine?
  4. Litaos
    Litaos New Member
    Argentina
    sorry, it's a xj 750 82'
  5. cds1984
    You mean speed as in RPM and standing still I'm taking it.
    If that's the case grab a piece of dowel and put it at different points on the engine while putting it against your ear.
    It will conduct the sound more accurately to try and determine where the noise you are hearing is coming from.
    Is it a clack or a grinding noise or a cracking noise or a ...
    I'm pretty sure we can help but you need to be more specific.
  6. cds1984
    FYI:
    There are 3 chains inside the engine.
    Cam chain - stretches and creates timing issues and general slapping.
    Oil pump - can't see it ever having an issue.
    Primary drive chain - stretches and breaks down the primary chain guide and eventually either shears off the oil spray nozzle or damages it enough to reduce oil coverage to the starter clutch.
    The primary drive chain is used by the starter and the alternator on the 750.
    Litaos likes this.
  7. hogfiddles
    What is the noise it’s making??
    Litaos likes this.
  8. Litaos
    Litaos New Member
    Argentina
    CDS1984 / hogfiddles.
    The sound is difficult to describe. Looks like a loose chain. It's important to know that this started right after I pushed it to start because the starter relay broke. For that reason I checked the timing chain and found that it is in good condition. Synchronized. Loose part or chain noise seems to be coming from below. The bike has 30,000 miles of use. I have no problem disarming. The engine was never opened. Thank you very much for the information you can give me. Sorry for the translation.
  9. Litaos
    Litaos New Member
    Argentina
  10. hogfiddles
    Still not making sense. Can you make a short video of it and post it here so we can hear/see what’s happening ?
  11. Franz
    Franz Well-Known Member
    Scotland UK.
    Litaos likes this.
  12. Litaos
    Litaos New Member
    Argentina
    Hello Franz .
    The changes come all. I put them on while turning the wheel.
    - Take out the spark plugs.
    - I put gear 1.
    - I turned the rear wheel carefully and it makes no noise.
    - I repeated the process in all gears.
    - When I start with the spark plugs on, it makes a noise like a loose piece.
    The 30,000 miles is real. I will try to upload a video.
    Thank you very much
  13. Franz
    Scotland UK.
    Let us hear it that's the best way with the video.
    Litaos likes this.
  14. Litaos
    Litaos New Member
    Argentina
    hogfiddles
    Yes, I'm going to upload a video because the error puzzles me. Thank you very much!
  15. Franz
    Scotland UK.
    Have you checked your exhaust for loose parts at the cylinder head header pipe joint. Make sure all the exhaust joints are tight. Exhaust rattles are an easy check to make.
  16. cds1984
    You know that baffle in the original collector can make a helluva racket when it rusts out too.
  17. Franz
    Scotland UK.
    Yes more likely something like that.
    Litaos likes this.
  18. hogfiddles
    I’m not gonna guess at anything til I hear/see it
  19. Litaos
    Litaos New Member
    Argentina
    hogfiddles / Franz / cds1984
    hello!
    I couldn't film for the following reason.
    2 days ago I loosened the timing chain tensioner to inspect if it was getting tight. I just loosened it and retightened it.
    Yesterday I put the spark plugs in and cranked the engine.
    It didn't make noise.
    I hooked up a higher power PSU to gain rpm and it didn't make any noise either.
    Since the carbs were out of fuel, I injected a flammable spray to give it a little more RPM and film the damage.
    The motor made a few explosions but did not make a broken noise.
    I put in the gas tank and fueled the carbs.
    I cranked the engine and the bike started without any problems. No noise broken.
    I let the bike run for a few seconds, then I put all 5 gears. Without noise...
    Then today I put in a beautiful 100 miles and the bike handled really well. I must admit that now at low revolutions (1050 RPM) it behaves better than before.
    Was the timing chain loose?
    Could it be that by loosening the tensioner, something was adjusted and that is why it now responds better?
    or I have to worry because at any moment it leaves me lying on the road.
    Anyway, today I spent an unforgettable day of 25 degrees Celsius with one of my children, riding our Maxim girl.
    hello!
  20. hogfiddles
    Based on your explanation and description, I’m going to venture a guess:
    1. your battery is low
    2. With plug removed, there’s no compression so the engine turns over easily even with a weak battery
    3. With plugs in, the battery is too weak, and your STARTER CLUTCH is not engaging firmly, so it jumps out and rattled around . Eventually it may catch and try to start, especially with starter fluid.
    4. Adding a booster to the battery gives it the amperage it needs to start normally.
    5. So my deduction at the moment is: you simply need a new battery.
    again, that’s just a guess from trying”read between the lines”........
    dfox
    Andrew Nichols and Franz like this.
  21. Litaos
    Litaos New Member
    Argentina
    Thank you very much for taking the time to write to me.
    I know it's hard to understand me without demo video.
    The battery is new, (yhuasa 12N14 - 3A).
    As it was three months without use, I connected a power source to get more revolutions at startup.
    Now the bike works properly.
    I am afraid that something that was left without proper repair will suddenly break.
    Thank you very much and sorry again for the translation.
  22. hogfiddles
    It’s not uncommon for a new battery to be a bad battery. Sounds like yours is a bad battery even though it is new.
    it IS also possible that you left a key on, or possibly had the key turned to the “locked with lights on” setting and drained your battery.
  23. Litaos
    Litaos New Member
    Argentina
    Good observation, I'm going to check if the circuit has any leaks. Good date
    cgutz likes this.
  24. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Plus one on the new battery being bad. My last replacement was bought new this spring, was sluggish from the get go, and crapped out after a few months. It tested fine on the bench, but for some reason won't hold a charge very long, and has from the beginning cause sluggish cranking.
    Next time I think I may try an AGM battery.
  25. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    .." It wouldn't be the first new battery I've seen go bad "...
  26. Litaos
    Litaos New Member
    Argentina
    I bought a good brand battery about 6 months ago, then the motorcycle was stopped for 2 months, currently I made measurements of the alternator charge. The voltage regulator cuts fine. Battery voltage doesn't drop much when cranking. For now it is in the normal parameters.
    Good luck with the purchase of AGM !!
  27. Litaos
    Litaos New Member
    Argentina
    To rule out electrical damage, I made the measurements and the alternator load, the voltage regulator works correctly.
