TO DO:
on-hold - Swap out the exhaust - see how paint holds up.
Change the seat and maybe a frame loop
Swap on the XJ550 tank
new electrical harness and fuse box
DONE:
PRACTICAL / COSMETIC
Drag bars
Tommaselli - Italian natural gum rubber grips
Midnight Maxim front fender
front and rear pegs
fork gaiters
MECHANICAL
Progressive 12 shocks
Nissin Master Cylinder
Retro slim master reservoir
Clutch lever and perch
All cables replaced
Front brake line and all banjos etc.
on/off road tires
bar end mirror
other bar end to match and stop wobble.
Valve shims checked and adjusted
All brake pads/shoes replaced
ELECTRICAL/LIGHTING/INSTRUMENTS
All wiring moved under tank
Ford style rear light
Bates headlight - powder coated
single mini tachometer
single mini speedometer with informational lights
smoked amber turn-signals
New NGK spark plug boots and leads.
PAINT
VHT Racing Green, Yamaha decal and 2K clear - Tank.
VHT black caliper paint - forks swing arm and drive shaft.
VHT black matte - front and rear fender and side covers.
VHT Engine Paint black metallic - Mufflers & Engine
VHT Flame Proof header paint flat black - Headers
Midnight Street Tracker Stealth Machine (aka 1981 Xj650).
XJ Garage item created by Ribo, May 23, 2015
- Year:
- 1981
- Make:
- Yamaha
- Model:
- XJ650
Franz, ctgergley, CactusJack578 and 13 others like this.
Sort Comments By
