1981 xj550 seca air box question
Discussion in 'XJ Technical Chat' started by Lyrichadden, May 10, 2018.
  1. Lyrichadden
    Lyrichadden New Member
    Madison, Oh
    I just purchased an air box and was wondering if I have to remove the engine to install it, or if there is an easier way? Thanks
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    On my 650 I removed the carbs, intake boots, and starter. With some careful maneuvering I got it in there with no real issues. Not sure if that would work the same on a 550 or not
  3. chacal
    Loosen the rear engine mounting bolt, and remove the front engine mounting bolts to allow the engine to "tip" forward a bit.
    You'll still need to do all this, of course: remove the carbs, intake boots, and starter.
