1981 xj750 front brake caliper rubber thing
Discussion in 'XJ Technical Chat' started by xjmat, Sep 26, 2017.
  1. xjmat
    xjmat New Member
    NSW, Australia
    I am cleaning my brake calipers and putting in new o-rings. There is a pin that keeps the two halves of the caliper together. The channel it runs through has a rubber boot on either end of it (see picture). Do those rubber boots come out? I gave them a bit of a pull, but they seem quite reluctant...
    Also, there are two square channels that were filled with crap of some sort - are they just meant to be cleaned out, or should they hold something (a shim lies over the top of them)?
    https://imgur.com/a/5prCN
    those boots come out but not easily leave them alone as thay are costly to replace. with only 1 source known for them
    just clean the channels
    Jetfixer likes this.
  3. Jetfixer
    Leave them be ...just clean them and put some silicone or armor all on them .
    +1 and +1
    Leave the boots on unless they have failed. The block runs clean and dry. The channels are there to give road grime a place to go, so the mating surfaces stay clean.
  5. PJC750
    PJC750 Member
    Northeast
    Just cleaned my calipers too...the boots are good except one has small crack. I could prob add break grease via a needle tip to fill the boot? Any suggestions? I am considering buying pair from Len $33 . To your point, they did not pop out when i was cleaning the channel. I didnt want to tear them either, tried to be gentle with my work. I added grease etc to insert the pin( I was trying to pack the boot with grease, not really successful).
  6. PJC750
    PJC750 Member
    Northeast
    Leaning towards letting sleeping dogs lie.
