1981 XJ750 Seca Front End Swap
Discussion in 'XJ Technical Chat' started by Bilby, Jan 29, 2024.
  1. Bilby
    Bilby New Member
    Queensland Australia
    The front fork assembly on my latest resurrection (XJ750) is completely stuffed. I have the chance to pick up a complete (including brakes and master cylinder) front end from a 1981 XV750. My question is will it fit?
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    although i can't answer your question with any cirtainty, are you going to use the triple tree from the xv, or swop the fork legs into the xj triple tree. if using the xv triple tree, it may just be a question of obtaining the correct size bearings to suit the frame and triple tree, if swoping the legs, can you measure both sets of legs to see of they fit .
    have you considered the xv only has a single disc up front ,the xj has twin discs with quite a bit more power from the engine than the xv?
  3. Dan Gardner
    Minneapolis, MN
    From the parts catalog, they look pretty different.
    Most notably, XV only has a single caliper and of course XJ750RH has the anti-dive units.
