1981 xj750R front brake caliper shim with ferrodo 277P pads
Discussion in 'XJ Technical Chat' started by xjmat, Sep 28, 2017.
  1. xjmat
    xjmat New Member
    NSW, Australia
    Hi,
    I have the ferrodo 277P pads for the bike. I have the calipers cleaned and new orings and all ready to go.
    When I assemble the brakes, I can't insert the pin through the hole in the pads while the shim is in (shim in pics included - one pic with shim in the brake assembly, one pic with shim next to it). I also can't see the shim on the parts fiche. Perhaps there isn't meant to be a shim? maybe it came with the last pads that were installed? Can I leave the shim out? The pads are snug without it, in fact the pin is stiff to insert even without the shim.
    I've said shim a lot now.
  2. xjmat
    xjmat New Member
    NSW, Australia
    On very close inspection, it seems the shoulders of the Ferrodo 277P pads are just very ever so slightly higher than on the old pads, The old pads go back in, which is nice: it implies I haven't bent something getting them out. Perhaps I should shave down the shoulders of the new pads? Is that a thing?
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    The shim is meant to be there, sounds like the pads you bought are not meant to be there.
    Can't think of any reason why you couldn't alter the profile of the pads to make them fit. After assembly I would be sure to test functionality with a very close eye.
  4. Stumplifter
    near Irma, WI
    Wait a minute... quick cross reference indicates that the 277P is for an RD 350.
    Click the XJ4EVER icon and get the right pads.
    XJ550H likes this.
  5. Polock
    i grind car pads all the time. China don't make them like they used to
  6. XJ550H
    you have to adjust the hole in the pad that the pin goes through with a round file. look at your old pads and you will see it is a little different.
  7. XJ550H
    HCP1705 Aftermarket standard organic front DISC BRAKE PADS SET, enough to do one front caliper. No wear-limit groove. NOTE: pad retaining pin hole may need a slight amount of filing or reaming for a perfect fit. Fits all XJ550 models, 1981-83 XJ750 Seca, XJ750 Euro, models, XJ1100 front calipers, and 1981 XS1100 Midnight Special front calipers.
    HCP1707 Aftermarket standard organic front DISC BRAKE PADS SET, enough to do one front caliper. No wear groove. NOTE: pad retaining pin hole may need a slight amount of filing or reaming for a perfect fit. Fits all XJ650 Turbo models and all 1981-83 XJ750 Maxim and Midnight Maxim models. These pads will also fit the 1982-83 XS400 and XS400R models. Each set:
  8. chacal
    Only if you want the brake pads to rattle constantly.
    As long as the slight shape/profile of the brake backing plates is the ONLY difference, then that should be a POSSIBLE solution.
  9. xjmat
    xjmat New Member
    NSW, Australia
    Thanks all! These are helpful responses.
    I would have bought the pads from xj4ever, but the shipping to Australia starts to get heavy. The ferodo website lists the 277P as for this bike (and I got them from Yamaha!! sheesh). I will give it a shot with grinding the hole to the same profile as the other pads. Super careful. Super gentle. And test.
    Stumplifter likes this.
