1982 maxim 750 flasher
Discussion in 'Hangout Lounge' started by lawnmowerman, Apr 18, 2020.
  1. lawnmowerman
    lawnmowerman New Member
    michigan
    i have a bad flasher for my blinkers can anyone tell me of one that will fit . the one i am trying to replace is a FU257cd
  2. OGMilkman
    OGMilkman New Member
    Downers Grove, IL
    Chacal(username on here, his website is xj4ever.com) definitely has a bunch of options. If I recall correctly, the OEM ones are like ~$90 ish, or you can go aftermarket for like $15-$30 depending on if you have LEDs/care about the auto-shut off working/care if you have to rig up your own mount
  3. OGMilkman
    Downers Grove, IL
    (directly from his catalog, other options may be available elsewhere)
    http://www.xj4ever.com/catalog/d-13-turn-signals.html
    HCP423 OEM turn signal FLASHER. For all 1981-82 XS400, all XJ550, 1981-83 XV750 Virago, 1981-83 XV920 Virago, XJ1100, and 1981 XS1100 models. Comes with a mounting grommet. These units will not work with LED bulbs.
    $ 114.95
    HCP22647 OEM turn signal FLASHER. For all 1992-96 XJ600 Seca II models. Comes with a mounting grommet. These units will not work with LED bulbs.
    $ 99.95
    HCP22648 OEM turn signal FLASHER. For all 1997-98 XJ600 Seca II models. Comes with a mounting grommet. These units will not work with LED bulbs.
    $ 96.95
    HCP424 OEM turn signal FLASHER. For all XJ650, all XJ750 non-X, and all XJ900RK, RL, and N/FN models. Comes with a mounting grommet. These units will not work with LED bulbs.
    $ 114.95
    HCP425 OEM turn signal FLASHER, CANCELLER, AND RELAY MODULE UNIT. For all 1984-85 FJ600, XJ700, and XJ750-X models.
    $ 159.95
    HCP14788 Aftermarket solid-state turn signal FLASHER. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will not work with LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit will not operate properly with this style flasher, and it must be by-passed via the use of the HCP16880 adapter plug below. Will require the use of the HCP11105 or HCP15149 mounting grommet.
    $ 21.95
    HCP16921 Aftermarket solid-state turn signal FLASHER. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will work with both incandescent and LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit will not operate properly with this style flasher, and it must be by-passed via the use of the HCP16880 adapter plug below. Will require the use of the HCP11105 or HCP15149 mounting grommet.
    $ 17.95
    HCP353 Aftermarket heavy-duty, solid-state turn signal FLASHER. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will work with both incandescent and LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit will not operate properly with this style flasher, and it must be by-passed via the use of the HCP16880 adapter plug below. Will require the fabrication of a mounting method as the original size grommet will not work.
    $ 19.95
    HCP353A Aftermarket heavy-duty, solid-state turn signal ADJUSTABLE-SPEED FLASHER. Same as the HCP353 above, but this unit has an adjuster screw that allows you to set the frequency of the flasher on/off performance. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will work with both incandescent and LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit will not operate properly with this style flasher, and it must be by-passed via the use of the HCP16880 adapter plug below. Will require the fabrication of a mounting method as the original size grommet will not work.
    $ 24.95
    HCP25332 Aftermarket solid-state turn signal FLASHER. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will work with both incandescent and LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit WILL operate properly with this style flasher, and this unit does not require the use of the HCP16880 adapter plug. Will require the fabrication of a mounting method as the original size grommet will not work
    $ 32.95
    HCP16880 Aftermarket turn signal flasher self-canceller ADAPTER PLUG for use with our aftermarket turn signal flasher relays. The use of solid state aftermarket turn signal flasher units will defeat the original self-canceller unit, and in order for the aftermarket flasher relays to operate properly, you must bypass the original self-canceller unit. This completely "plug-and-play" adapter provides the proper ground path for the flasher relay, which the original self-canceller will not. Each:
    $ 16.95
  4. lawnmowerman
    michigan
    how do i purchase from xj catalog or call do you know
  5. hogfiddles
