1982 XJ650 Maxim Project
Discussion in 'XJ Technical Chat' started by MikeVT, Aug 11, 2020.
  1. MikeVT
    MikeVT New Member
    East Haven, Vermont
    New to this forum; any help much appreciated:
    1) Oil drain plug stuck (19mm). Any tricks? Been spraying it with PB B'laster numerous times, letting it soak overnight. Heat?
    2) K&N high-performance oil filter stuck. Also spraying with PB B'laster. Good idea to replace with stock filter cover?
    3) Battery low on fluid. Worth trying to refill? Best way? (Interstate brand, not too old.)
    4) Ding in rear wheel rim; may be allowing air to leak out. Fixable? Best approach?
    Thanks . .
  2. JCH
    JCH Active Member
    seattle wash
    Oil drain= You can try banging on it with a hammer and eye protection of course,if you have compress air and a air hammer seem's to works the best and is fast with a round headed bit or by hand is also a option.Be careful !!!
    Air filter= I use the stock filters.
    Battery=Yes,you don't want the plates exposed to air just fill above the plates.
    Ding= you will need or should remove the tire and can try banging it out with a large hammer and a piece of wood or really big mallet.
  3. Toomanybikes
    Tsawwassen bc
    Used wheels are cheap$30-40, it’s should be replaced.
