1983 midnight maxim master cylinder rebuild
Discussion in 'XJ Technical Chat' started by lawnmowerman, Apr 27, 2020.
  1. lawnmowerman
    lawnmowerman New Member
    michigan
    hello . i have put new brake lines on my bike cleaned calipers and slides greased fittings made sure everything slides as it should. i put in new dust seals on piston. pistons do not seem to totally let off the disc when i roll the bike it seems hard to push like the brakes are sticking and i hear a squeak when the wheel turns. brakes also have been bled well. next is the master cylinder does anyone have any tricks or advice to give me on the squeaking or the master cylinder rebuild
  2. Toomanybikes
    Tsawwassen bc
    Are the grooves for seals and dust seals absolutely sparkling clean? If not piston will not retract as they should. And a couple of mm of free play between adjusting screw and m/c piston.
  3. XJ550H
    did you have to modify the hole in the pads to get them to fit?
    Toomanybikes likes this.
  4. Toomanybikes
    Tsawwassen bc
    I forgot about that one, good call!
  5. lawnmowerman
    michigan
    no i guess i dont know about modifying the holes , just took the master cylinder apart and found the small hole in master cylinder was clogged i used a small torch file to clear out the hole
