1984 xj750 engine oil
Discussion in 'XJ Technical Chat' started by Remy Nelson, Apr 8, 2022.
  1. Remy Nelson
    Remy Nelson New Member
    Vancouver island
    Hi, I’ve just got a loan of an xj750 and the oil light has come on, is there a specific oil I should buy? Thanks.
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    15w40 Shell Rotella
    cgutz and Toomanybikes like this.
  3. Jetfixer
    The oil light is quantity, not oil pressure if oil quantity sending unit is dirty from lack of oil changes the float will stick . When you do the oil change it can be removed but exhaust system will need removed to get it out. Once removed you can clean it out.
    Franz likes this.
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    exactly how is the oil light showing? , if it comes on permanently ,when the ignition is turned on , then "Jetfixer" called it right,
    but if it just lights up when the start button is pressed, then that is a test facility for the bulb, and nothing to worry about
