1985 XJ700 Maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by Rawaterbury69, Dec 22, 2017.
  1. Rawaterbury69
    Rawaterbury69 New Member
    Jeffersonville,Indiana 47130
    Looking for a starter. This one I have doesn’t spin.
    Start a conversation with Chacal, he has rebuild kits in stock.
    Replacing your starter motor brushes w/ pics
    Also, have you confirmed that the starter is at fault?
  3. Toomanybikes
    Tsawwassen bc
    Same as all the other xj650/750's
    Get a starter repair kit from @xj4ever
    Len will get you the correct parts and quick
  4. hogfiddles
    Have you tried pushing the button?
    Got a good battery?
    Oh yeah..... Gotta have the key on, and the RUN switch set.
    Make sure your side stand switch isn't stuck shut, as well as the neutral safety switch......
    If you've done all that, put a direct line right from a good battery to the starter. If it doesn't spin THAT way, then yeah, your starter needs attention. If it does spin, you know to look elsewhere.
    Make sure you're in neutral.....
    xHondaHack likes this.
  5. Rawaterbury69
    Thanks for all the answers. It turned out to be the starter. Now I changed it out and it cranks but won’t stay running. Pulled the spark plugs and neither of the four match on gap. What are they supposed to be gapped at?
  6. Rawaterbury69
    I have to keep the throttle up just to get it running and it’s not really running well.
  7. hogfiddles
    That's more likely carburetor issues.
    I don't bother to gap the plugs.....I just stick them in and go.. I think the last time I gapped a plug was in 1984
  8. Jon Iszard
    Jon Iszard New Member
    Houston
    Gap should be at .032, but unless one or more is way off, this won't be your problem. My 85 xj700 is very cold-blooded - needs a bit of full choke on cold mornings.
    I'm thinking either you have a fuel issue, or a bad coil or other ignition issue. Check that each properly gapped plug is showing spark. If yes, probably a fuel issue.
  9. k-moe
  10. Rawaterbury69
    Well , I guess it’s a fuel issue. I have gas draining out of an overflow tube. Any ideas of what might cause that?
  11. hogfiddles
    1. At least one float is hanging open
    AND
    2. You have fuel flowing through a petcock even when your bike is not running. Either your petcock is bad, or you left it on PRI
  12. Rawaterbury69
    So I need to remove the carbs and clean them?
  13. hogfiddles
    Yes..... And service the petcock
    Paul Howells and k-moe like this.
  14. Jon Iszard
    Houston
    My Yamaha outboard does the same thing if I don't run it dry before storing it - the float needles tend to get stuck in the open position. You may have one or more stuck needle valves allowing one or more bowls to overflow.
