1985 xj700 wiring harness
Discussion in 'XJ Technical Chat' started by Gcxcountrystar1, Sep 11, 2016.
  1. Gcxcountrystar1
    Gcxcountrystar1 Member
    Hartford, IL 62048
    Are the 1985 xj700 and 1986 xj700 wiring harness the same.
    I bought a 1985 xj700 and the guy before me chopped up the wiring some.
  2. Wagy
    Wagy Active Member
    PA
    hey star, i'm workingon the wiring on my 85 700(air) and as far as i can tell ,they should be the same.
    my manual is for maxim X and it's all the same except fot the cooling system. BUT there are a lot of guys on here that know evertthing , so........
  3. xHondaHack
    Orange CT
    Make sure you get a wiring harness for the air-cooled 700. It will interchange between '85 and '86 so you should have no problem.
    Tony
    Gcxcountrystar1 likes this.
  4. XJ550H
  5. Wagy
    Wagy Active Member
    PA
    OK 550H, if you got some time , i have all the # from the ignition system on the 85 maxim700N.
    Primary/Ignition coil #1 - 3.3 ohms @ 200 setting
    " " #2 - 3.4 " "
    Secondary/Ignition coil #1 - 13.0 ohms @ 2000K setting (plug wire to plug wire, same coil)
    " " #2 - 13.0 " " (both readings with boots off)
    Wire plug boots #1 cyl. - 8.5 ohms @ 2000K
    " #2 " - 4.7 " "
    " #3 " 4.8 " "
    " #4 " 9.9 " " ( the two high readings look like replacement parts )
    Pick-up coils #1 - 116 ohms
    " #2 - 117 "
    Sidestand Switch UP - 0 ohms
    " Down open curcit
    Sidestand relay (?) w/power - 0 ohms ( any setting )
    " w/o power - 0 ohms ( shows a (-) infront of 0 reading ? )
    It seems like the sidestand relay is bad, as you said last nite, if you just un-plug that relay it will over ride that safety fetcher. All other readings seem to be ok , except for two wire boots that should be replaced, but not the reason of a no spark issue, Can you tell me where to go from here ?
  6. XJ550H
    you should keep this in the same thread possibly start your own thread to avoid confustion
  7. Wagy
    Wagy Active Member
    PA
    Now that i copied and paste all info into a new thread, can anyone help with the electrical snafu i'm having. ?
  8. Wagy
    Wagy Active Member
    PA
    New thread is Max 700N - No spark @ Tech chat
