1990 900 seca carbs
Discussion in 'XJ Technical Chat' started by Paul mills, Aug 8, 2018.
  1. Paul mills
    Paul mills New Member
    kelso
    Hi all
    I recently bought a new project 1990 900 seca, starting to do alittle work on it, in between other bikes, most of the bike seems o.k and apart from the fact that the carbs/ airbox are missing,paintwork is a bit tatty. obviously I need to get the engine running, so I can assess if any work is needing done. the question is can I fit a set of carbs of something else, say a 900 diversion, dont really want to fork out for a set and then probably spend the same again re-jetting to get the bike to run right.
  2. Simmy
    I'm a little confused by "1990 Seca 900".
    The Seca moniker was dropped after 83 for the 900's.
    So I assume you have an XJ900F.
    In this case the carbs from the Diversion will not work. They have downdraft carbs.
  3. k-moe
    It's also a bit confusing since the Diversion 900 wasn't sold in the U.S. (I'm assuming that the OP is in Kelso, Washington).
  4. kerriskandiesinc
    NY
    Could be Kelso, Scottish Borders......
  5. kerriskandiesinc
    NY
    900F UK/Seca...UK-US it DOES get confusing, lol...even without the 900'Divvy'!!!
  6. k-moe
    Well I went to your profile Mr. Mills, and found that you linked Kelso, AU as your location.
    I wonder if the forum software has a bug that isn't providing the location as a link in posts.
  7. Paul mills
    kelso
    just checked info on profile , told me I was where I should be, Kelso , scottish borders, sorry about any confusion but the bike is a 900f, actually thought they were called seca, but am wrong , yet again.
    Actually live about 7 miles from Kelso, if you look at a map of kelso area find the middle of nowhere and I am right in the middle.
    Any way thanks Simmy for the information about the divvy carbs
    just wondering if my internet problems are causing your server to think I am not where I am, checked speed a few days ago after the engineer had been out to fix it again and got 0.018meg download on broadband
