650 seca brake rod
Discussion in 'XJ Technical Chat' started by pottrd67, Sep 2, 2009.
  1. pottrd67
    pottrd67 New Member
    Need to replace the rear brake rod and can't seem to find one. Does anyone know if one from a different bike would fit. The 750 seca looks close but would hate to order it if it doesn't fit. Thanx.
  2. chacal
    XJ650RJ Seca and XJ650 Turbo share the same rod; all others are different. I should have a good used one if you are still in need............along with the pin, spring, clevis pin, etc.
  3. pottrd67
    pottrd67 New Member
    Thanx for the info. If I can't find one at the local shop, I will contact you. Thanx again.
