81 xj550 side cover tabs
Discussion in 'XJ Technical Chat' started by Tshutts, Jan 31, 2021.
  1. Tshutts
    Tshutts New Member
    Just got it back from total rebuild...sidecover tabs broken. Any help on re creating tab? Products? Cheers
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Fibreglass sticks to the plastic a charm and what can't you make with fibreglass?
    I have a sidecover with a bolt reinforced and shaped with some resin and fibreglass, that seats into my tank.
    Helps to get new rubbers mind you, stiff ones are good way to break the sidecovers.
    Silicon spray on the rubbers every now and again isn't a bad option either.
  3. mlew
    mlew Well-Known Member
    Apex, NC
    Most of these yamaha side covers are made from ABS plastic. I fixed mine with a sheet of ABS and glue for ABS pipe from the hardware store. It is easy to fab new tabs and glue them on.
    All of the XJ sidecovers are nmade from ABS.
  5. Polock
    sounds like a job for a 3D printer. i tried printing ABS, turns out I'm not as good as i thought :(
  6. hogfiddles
    We’re they broken before you took it in? If not, THEY should be on the hook to get replacements for you, or reimburse you for the damages.
