81 XJ650 - Will not change gears
Discussion in 'XJ Technical Chat' started by C-AUS, Jun 13, 2018.
  1. C-AUS
    C-AUS New Member
    Melbourne, Australia
    Hi all,
    I have the bike up on it's centre stand, and when I click through the gears, clutch in, it goes into first, up to second, and then most of the time it will not go any further. I am giving it a firm and confident push, but it just feels like mush, there is no actual gear change. This is backed up by when I work through the gears to first I only go down one full gear change, past neutral. Sometimes I can click through all the gears, but most of the time it refuses to work.
    Thanks,
    Charles
  2. Toomanybikes
    Tsawwassen bc
    Welcome Charles
    Sound like the spring for the gear change wheel is broken inside. It’s a fairly simple fix. Remove shifter and the cover and it’s easy to see what is wrong. This little wheel holds the drum in each position and if the spring has broken it is very hard to shift.
    C-AUS and Franz like this.
  3. Rooster53
    Also be aware that because of the design of the transmission you need to be rotating the rear wheel in order to shift through the gears.
    C-AUS and k-moe like this.
  4. kerriskandiesinc
    NY
    Could also be the dreaded alternator drive chain rubber/metal guide blade......they DO break up, with heat and miles, bits can get into the selector forks/drum and 'seize' in in gear......happened to me, twice in the past usually well North of 100,000 miles, although age MUST be a concern too.....
    C-AUS likes this.
  5. k-moe
    ^THIS^
    Check the easy things first.
    C-AUS and kerriskandiesinc like this.
