81 xj750rh seca cylinder interchange
Discussion in 'XJ Technical Chat' started by adamcastro, Aug 18, 2016.
  1. adamcastro
    adamcastro New Member
    louisiana
    looking for someone who knows if 81-83 maxim and seca cylinders interchange i have looked and they are different part numbers 562-11101-00-00 for 1981 and 562-11101-10-00 for 82 up whats the difference? can i use a later jug? mine has low compression 100psi 75psi 30psi 30psi
    They interchange. The different part number is due to the paint differences.
    Before you buy anything, have you done a leakdown test?
    Did the bike sit for long?
  3. adamcastro
    louisiana
    i accidentally put the head part number. no, all i did was check for fuel, and spark. it wouldn't run so i did the compression check. the guy i got it from was riding it last month but he was push starting it. the starter wasnt working. i bought a new starter and cant get it to run
    Did you actually see it push-start before buying?
  5. adamcastro
    louisiana
    no
  6. k-moe
    So the truth is that it wasn't being ridden at all.
    Do a wet comression test (1 tbsp oil down each spark plug hole), then do a leakdown test.
    If you're lucky the rings are just stuck (unlikely with how low the compression is).
    Check the valve clearances too.
    You may be buying new cylinders, but that should wait until you know whether it's better to tear the engine down, or just look for another.
  7. adamcastro
    louisiana
    thanks i oiled to cylinders now i have 150 125 125 125 so i ordered cylinders rings and pistons. can i take off the jugs with the motor in the bike?
  8. desmotom
    desmotom Active Member
    Canada MB
    yup you can
  9. adamcastro
    louisiana
    yes!!! made my day
  10. k-moe
    Be sure to get wrist pin circlips too. They should not be reused.
  11. adamcastro
    louisiana
    ok thanks
  12. adamcastro
    louisiana
    where does this vacuum hose go? its on the petcock, does it go to the intake boot?
  13. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Yes, one of them...usually #3.
    Gary H.
  14. adamcastro
    louisiana
    man, its good this forum exists!!
