82 xj750 seca valve cover torque setting?
Discussion in 'XJ Technical Chat' started by Nightdemn, Jul 30, 2013.
  1. Nightdemn
    Nightdemn New Member
    Visalia Ca
    Was the torque on the valve cover ?
  2. bigfitz52
    Only 7.2 ft/lb. There are stop collars on the bolts. You're only tightening them until they stop.
    This is why it's necessary to replace the rubber/metal composite "donuts" on the bolts. The donuts are what actually push the valve cover against the gasket/head.
  3. Nightdemn
    Visalia Ca
    Thanks Big ! Do you know a place to get them cheap ?
  4. dmlyster
    dmlyster Member
    Corvallis, Oregon
    I stripped out threads at 7.0 ft.lbs. I followed the spec's and got screwed, what a hassel. (This is with new pressure donuts!
    I'm suprised it wasn't mentioned ...... hand tighten until it stops, then tap Allen wrench with your finger to ensure firm. From experience I highly recommend NOT using torque wrench.
  5. Nightdemn
    Visalia Ca
    Thank, yah I read that in a couple other threads.
    I planed on using (blue) to help seal the gasket. Now to just get the donuts cheap. And is that what there called ? Lol
    Thanks for the help guys, you rock !
  6. bigfitz52
    XJ4Ever.
    Click the logo/link at upper right in the site banner, PM member chacal, or send an email to "info AT XJ4Ever DOT com" with your info.
  7. Nightdemn
    Visalia Ca
    Thanks man ! :)
  8. CHassan
    CHassan Member
    Maineville, OH
    I got the "doughnut installation tool" Chacal sells. I tried one or two without it, and did the rest with it. It wasn't that hard to do without it, but the tool made it much much easier. For the $2.00 it cost it I thought it was worth it.
    To get the old buggers off I cut the rubber down each side. I took a pair of tin snips and cut the metal on one side. Grabbed the rubber with pliers and pulled it off. Twisted a large flat screwdriver between the cut I made in the metal and gave it a twist. This would spread the metal enough to slip off over the threaded end of the bolt.
    Took me about 20 minutes to do all of bolts.
  9. Nightdemn
    Visalia Ca
    Thanks CHassan !
