'83 XJ650 Parts
Discussion in 'XJ Technical Chat' started by SpearChucker, Mar 21, 2019.
  1. SpearChucker
    SpearChucker Active Member
    Prince George, BC, Canada
    I'm not sure if anyone is familiar with Hoop Rider out of Owen Sound, Ontario, but I was on the site, hoopriderparts.com, looking for Seca 900 parts and saw this:
    2018-10-20
    1982-83 Yamaha XJ650 Maxim Parts
    We're currently parting out a 1982-83 Yamaha XJ650 Maxim. These parts are not yet listed in the online store. Please contact us for shipping quotes or pictures.
    Complete frame with swingarm and title $150
    Complete engine (80,322km) $150
    Front brake rotor $20
    Front fender $20
    Rear shocks (pair) $30
    Headlight (lens and bucket) $20
    Horn $5
    Relay (FU257CD) $10
    Relay (4U8-00) $10
    Relay (3H5-00) $10
    Relay (4H7-01) $10
    Signal cancel relay $10
    CDI/Ignitor $40
    Battery box $10
    Fuel petcock $15
    Voltage rectifier/regulator $50
    Shift pedal $10
    Driveshaft $20
    Drive shaft universal joint $20
    Mirrors (pair) $20
    Right hand switch set $25
    Front brake master cylinder and lever $25
    Front brake caliper $20
    Clutch lever $15
    Brake rod assembly (rod, pedal shaft, spring) $20
    Air box $15
    Instrument panel/cluster $30
    Speedometer cable $20
    Handlebar $10
    Main wire harness (needs repair) $40
    Front signal lights (pair) $20
    Rear signal lights (pair) $20
    Rear mag wheel/rim $40
    Rear axle $15
    Rear drum brake cover with shoes $20
    Rear hub final drive gear assembly $20
    Front mag wheel/rim $35
    Front Axle $15
    Speedometer driver $15
    Complete front fork assembly $90
    Starter motor $60
    Ignition coils (pair) $60
    Brake pedal $20
    Tool box $10
    Grab bar $20
    Front brake lines $15
    Side stand and spring $20
    Complete left exhaust $40
    Complete right exhaust $40
    Rear tank mounting rubber $5
    Front tank mounting rubbers (pair) $5
    Driveshaft universal joint boot $10
    Rectifier/relay mounting bracket $5
    Centre stand & spring $20
    Front fork brake hose guide $5
    Front fork wire harness guide $5
    Engine mounting bolt/bracket set $15
    Choke cable $15
    Clutch cable $20
    Fuel tank $80
    Seat $35
    Starter motor wire $5
    Aluminum peg mounting side rails (pair) $20
    Side stand switch $10
    1982
    1983
    maxim
    xj650
    yamaha
    Thought I'd pass it along.
    Ryengoth and Franz like this.
  2. Simmy
    This is where I bought a few spare motors.
    He is generally cheaper than other breakers
  3. k-moe
    Yep. Those are the prices I was seeing in 2007. Rarely do you find an engine listed for less than $300 anymore.
  4. Simmy
    paid $75 for a 900 and $50 for a Turbo.
    both left in the weather for a while. both missing starter motors, no clutch in the Turbo.
    All I wanted was the Turbo cases & crank and the 900 crank, rods, pistons and block to play with.
