85 xj700 wiring problem
Discussion in 'XJ Technical Chat' started by Gcxcountrystar1, Apr 16, 2017.
  1. Gcxcountrystar1
    Gcxcountrystar1 Member
    Hartford, IL 62048
    So I'm replacing the wiring harness that came with the bike the guy before me hacked it up. I do not have the brown connector on the speedometer that comes from the temp gague on the harness
  2. Gcxcountrystar1
    Hartford, IL 62048
    This is the connector on the temp gague on the speedometer
      File size:
      26.4 KB
  3. k-moe
    Were you careful to get the wiring harness for an XJ700XN, and not an XJ700N?
    There are two XJ700 models. One watercooled (like yours) and one aircooled.
  4. Gcxcountrystar1
    Hartford, IL 62048
    It's the wiring harness that was in a box of parts I got from the guy
  5. k-moe
    Then it may be the wrong harness. Can you call the PO and ask?
  6. Gcxcountrystar1
    Hartford, IL 62048
    I called the guy I bought it from he said that was the harness that he got when he bought it from a guy
  7. k-moe
    Oh good. Well unless there are obviously clipped wires I'll go ahead and say that it's not the correct harness.
    This diagram should help you figure out what you have (wire colors are the same as in the actual harness).
  8. Gcxcountrystar1
    Hartford, IL 62048
