Adjustable Clutch and break levers.
Discussion in 'XJ Technical Chat' started by EvilMonkie, Jun 6, 2018.
Tags:
  1. EvilMonkie
    EvilMonkie New Member
    Calgary, AB
    Hello all,
    I am brand new in to riding. I have a 1983 Yamaha xj750 maxim, and honestly this is my first real bike.
    But I have a problem, the reach on the Clutch and Break levers are a stretch. I was told to look in to Adjustable levers to replace them. But all the one i have found are for xj650.
    Do you know if they will fit the 750 or which ones would be good to get?
    J
  3. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Make sure you pay attention to the bore/piston diameter whatever master cylinder you go with. Which as far as I know is the real difference between 650 and 750 mc's because of the single disc vs twin disc
    He's just looking for levers, not new master cylinder.
    Far too many Ebay sellers say everything fits everything.
    Jetfixer likes this.
  5. k-moe
    Start a conversation with chacal.
    If there is an adjustable set of levers that fit correctly, he will have them.
    Keep in mind that the levers have a distance of travel that must be maintained for the controls to work correctly. I'm not sure that there are levers that can come closer to the bars and still maintain the correct amount of throw.
  6. Polock
    my Suzuki adjustable levers move the engagement point but not the position of the lever at rest. a dog leg type lever might rest closer to the grip
    Jetfixer and k-moe like this.
  7. EvilMonkie
    Calgary, AB
    Thank you all for your help!
    J
