Any easy fork circlip removal ideas?
Discussion in 'XJ Technical Chat' started by Greggy, Mar 29, 2017.
  1. Greggy
    Greggy Member
    Ohio
    I am trying to change my fork seals and am already stuck at the first part, removing the clip, I can't keep the cap held down and remove the circle at the same time, does and one have any ingenious ideas? Help is greatly appreciated. Thanks
  2. mlew
    mlew Well-Known Member
    Apex, NC
    I use a floor mounted drill press with a 3/8 rod in the chuck to push the center down. Its a little tricky with one person but can be done. Others have modified c-clamps to do the job, I have seen it here but cant find it. I use my drill press so I don't have another tool to keep track of.
  3. Quixote
    Quixote Active Member
    Victoria, BC, Canada
    If you can find a clamp like this, it would be ideal.
  4. Quixote
  5. Polock
  6. k-moe
    I used to keep a teenager around for just that reason. Unfortunately he moved out.
    Having a helper is always helpful.
  7. Greggy
    Greggy Member
    Ohio
    Awesome, three way clamp looks cool, I like Pollock's idea and it will be free, thanks for the suggestions
  8. Jetfixer
    I use a BF screw driver push down on cap with one hand and use free hand to remove clip with a bugger hook ...But I'm strong I guess lol
