Anyone happen to have a Ducati Monster? Need measurements
Discussion in 'Hangout Lounge' started by saftie, Dec 28, 2017.
  1. saftie
    New York, NY
    Hey,
    Just throwing this one out there. Does anyone happen to have a Ducati Monster?
    I am looking for the mounting hole dimensions for the tail frame.
    Basically I'd like to know how far they are apart. Trying to get creative on my bike and maybe put on a monster tail frame.
    Here a link to a pic to show what I'm talking about:
    http://i1217.photobucket.com/albums...00/Screenshot_20171228-085432_zpswiiysysm.jpg
    Thanks a bunch,
    Gabor
  2. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    There’s about 40 different versions of the Monster, from 400cc to 1100, air or water cooled, plus three different generations.
  3. saftie
    New York, NY
    Yes. The idea was to get the measurements and what year and model. Maybe I should have mentioned it but I thought it was obvious.
    Anyhow, i think I am going to save money and just modify my existing tail.
  4. LarryMc
    LarryMc Active Member
    Lakewood, WA
    I have two 2010 "696" Monsters in my garage if you want measurements. Let me know if you change your mind.
  5. saftie
    New York, NY
    Oh perfect. Yes please :)
    I'd also like to know the across measurement.
    Here is what I have mocked up so far using an old tank. But I'm still open to a swap, even if it's just the frame and not the plastics. Not sure if the angle would be right or if mods are needed. But in either case, something would have to be cut/glued/welded.
  6. LarryMc
    Lakewood, WA
    I'm working out of town until this coming Friday. I'll be decompressing from work in the garage this weekend and will provide your requested measurements gladly.
    The following image is what you want measurements of, the "seat subframe assembly" fastening points, correct?
  7. saftie
    New York, NY
    Yes correct. Basically I am trying to figure out how close this comes to fitting my frame to replace the current tail frame. Here an old pic of the frame where you can clearly see the anchor points.
    I understand that modifications might be required, just want to see how close it is. Oh, I would also need to know the measurement from side to side.
  8. saftie
    New York, NY
    Oh... I just took a closer look and realized how the frame is used/attached on a monster. The longer side actually goes towards the engine and mounts there, correct? So this won't work then. Looks like i have to focus on the hole in the middle. So I'll need the measurement from the middle hole to the one facing back on the bike.
    I think you'll get the idea of what I am trying to do when looking at my above picture.
  9. LarryMc
    Lakewood, WA
    I believe I'm picking up what your putting down. What I'll do is take a picture of what I'm measuring, and indicate from point to point what the distance is. Here is a CAD image if how the subframe marrys up on the 2010 Monster ducati-monster-696-pieza-7.jpg
    Stumplifter likes this.
  10. LarryMc
    Lakewood, WA
    BTW, is that a 1995 VFR800 your working on?
  11. saftie
    New York, NY
    Cool, thanks.
    No, it's an 88 FZR1000. She's been through a few changes already, like custom built subframe plus custom seat, now a different swingarm (to allow a 17 inch 180 tire) etc. Here a link to my website where I photo document stuff. There is a section about the current subframe: gabobobikes.com/Kinga
  12. LarryMc
    Lakewood, WA
    Got in early this evening instead of first thing this morning. Thanks for your patience.
    Anyhow, my Monsters are actually 2013 models. We traded the 2010 models on for the 2013s.
    So referring to the image below: the distance between 1 and 2 is 7 3/4" from center to center.
    The distance between 2 and 3 is 7" center to center.
  13. saftie
    New York, NY
    Ok thank you very much.
    This won't work then without bigger modification. I'd have to use hole 2 and 3 but have 7 3/4 on my frame. Oh well, it was an idea.
    I'll continue down the path of modifying my current one and use the tank as tail piece.
    Thanks again, I really appreciate your time and taking the measurements.
  14. saftie
    New York, NY
    Btw how come your chain looks so clean? Is it lubed?
  15. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I was wondering how EVERYTHING looks so clean! Is that bike in a showroom?
  16. LarryMc
    Lakewood, WA
    You win some you loose some with mods. Don't ask me how I know this. It would be the longest post ever.
    The chain and sprockets were replaced before the past riding season on both Ducatis. Plus the fact that I'm OCD when it comes to my vehicles is why it's so clean.
    My secret weapon is I use Dupont Multi-use Teflon spray lube, it literally provides the least "cast off" of any chain lube out there. Dupont sells several variations of Teflon spray lube so to get the correct stuff make sure it's item number D00110101. (see image attached) Read the reviews and comparison tests. It, hands down, always wins real world testing, every time. Great stuff, try it and you'll never use anything else, ever.
    The only catch is you have to start out with a virgin chain or one that is perfectly clean for the stuff to provide these results. Sprockets must be spotless also. I have 5 bikes and changed the drive chains on all of them after discovering this stuff with in two year period.
    Additionally, chain and sprocket noise is silent or nonexistent which seems to be something people just come to terms with. Your chain actually should not be a noisy component of your bike if maintained and adjusted correctly. Remember how quiet the chain was when it was new? This stuff combined with a clean unworn chain and sprockets is the shit.
    Honestly.
  17. LarryMc
    Lakewood, WA
    Speaking of long posts⤴️
  18. saftie
    New York, NY
    Oh nice, I will read about this. Too late for me though, my brand new bike is already used and the sprocket change on my other bike has seen 300 miles already.
  19. k-moe
  20. LarryMc
    Lakewood, WA
    Too much coffee when we went out for breakfast this morning. Composed that post while waiting to be served and chugging coffee. Crashed hard this afternoon and after waking up I noticed my hand was quivering a little. Nothing a shotgunned Red Bull won't fix.
