Bad tire, bad mounting?
Discussion in 'XJ Technical Chat' started by SQLGuy, May 9, 2021.
  1. SQLGuy
    SQLGuy Well-Known Member
    I got my new tires installed last week. Michelin Pilots.
    I pulled the wheels and had a local shop mount and balance the tires.
    When I took my first ride with the new tires, I noticed vibration and sort-of bouncing, even on very smooth roads.
    Looking at the rear tire with the bike on the center stand, I saw that, which the wheel seemed to be running true, the tire has a back and forth wobble (I'll see if I can post a video). I also noticed that the ridge of molding near the rim edge sticks out an uneven amount from the rim from one side to the other. Near the stem there's about 1.4mm visible, while, around the side opposite the stem there's over 3mm.
    Wondering if this is a bad tire, or something about how it was mounted. I used to install car tires when I was in college and never saw any issue with mounting that could cause a tire to be off-center, but maybe there are such considerations for motorcycle wheels?
    Thanks,
    Paul
  2. tj.
    tj. Active Member
    Canada
    You referring to the bead line?...pic attached
  3. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    Perhaps it's the wrong size tire or poor mounting. I hope they didn't bend the rim.
  4. SQLGuy
    Yes
  5. SQLGuy
    They are the correct size tires. Same as previous. 120-90/18.
    Only the tire is wobbling, not the rim edge.
  6. StahlMaster
    Southgate, Michigan
    If the rim is true, I'd suspect poor mounting. The bead is not set right. Is it mounted in the correct direction?
  7. SQLGuy
    Yes, the directions are correct for both. The arrow is much more subtle on the rear one, though.
  8. tj.
    tj. Active Member
    Canada
    The bead line must be even all the way around...that is the purpose of the bead line. If it is not, then the bead isn't seated properly. Take it back to where you had it mounted.
    StahlMaster likes this.
  9. StahlMaster
    Southgate, Michigan
    How in the hell did they balance it!!
  10. Simmy
    You can try pumping it up to 50-60 psi to see if it pops in place.
    If not then take it back as @TJ stated
    a100man likes this.
  11. Polock
    take the wheel off, let the air out, step on it where it's in question, it should pop off the bead because it's not really on the bead, spray the area with (i use foamy window cleaner) something,
    and put air in it till it pops on, no problem. i've never had a "professional" mount a tire. if he didn't balance the wheel before he mounted the tire, there's too much weight on it
    Minimutly, k-moe and a100man like this.
  12. a100man
    a100man Well-Known Member
    Bedford, UK
    I've had problems in the past with tyres not sitting concentric with the rim - more so with tubed set-ups. Can be hassle to 'cure' but if you paid a shop to do it they can try again - unless you want to.
    It's a reminder to all of us check them before you leave the shop.
  13. SQLGuy
    Not that easy to check in the shop. It's not even that easy to see on the bike until you're looking for it... i.e. start the bike and put it in gear while on the center stand.
    I've had probably four sets of tires mounted and balanced by these guys. One set while on the bike, the other three sets with me bringing in the wheels and tires. First time I've had a problem.
    When I was in college, I installed tires at Sears. Never saw a tire not sit right like this.
    And, as to Polock's comment, no, we, at least, never balanced a wheel first, before installing a tire. I was always taught that you wanted only one set of weights per side per wheel. Stem markings, for tires that have them (I think they're going away now) are supposed to offset versus typical light points of wheels, too, and result in less weight. Maybe some places do this with balancing the wheel first, but I've never seen it and I don't know why to expect that that would be more likely to result in less weight.
  14. tj.
    tj. Active Member
    Canada
    Balancing the rim without weights and tire on, determines where the heavy spot is. You would think it would be at the valve but I rarely find this to be the case...usually it's close, but sometimes I'm surprised how far off it is. If you match the "stem mark" on the tire with the heavy spot on the rim you would have less weight than just putting the "stem mark" by the valve. Personally I've never found it to be more than a fraction of an ounce.
    I'm doubtful that any tire shop would bother to do this, unless it has a lot of weight added...
    Doubtful they check runout either, unless you ask.
  15. SQLGuy
    Unless you know where the heavy spot of the tire is, what good does it to do you to know where the heavy spot of the wheel is? New tires often don't seem to have stem markings. You'd have to balance the wheel, mount the tire, then see where the new heavy spot is, then, probably, unmount the tire, remove the weights from the wheel, remount the the tire to offset the tire and wheel heavy spots, then rebalance again. If I had my own dynamic balancing machine and tire mounting machine, I might do that. I guess a shop might, too, if you are willing to pay them two to three times the normal mounting and balancing charge.
    Runout of this tire, as mounted, is about 35 thousandths. It's pretty obvious to the eye with the wheel spinning and the bike on the center stand.
  16. tj.
    tj. Active Member
    Canada
    Yes, knowing where the light spot of the tire is key.
  17. Polock
    you put the tire on the wheel, put it on the balancer, no air, and spin the tire on the wheel till it's close or your dots line up, air it up and balance it
    my cheap tires all have dots
  18. SQLGuy
    If you know where the heavy spot is, you know where the light spot is. They will be 180 degrees apart.
  19. SQLGuy
    My cheap tires (Shinkos) also have stem markings. These Michelins do not.
    Regardless, you are talking about static balancing, not dynamic balancing. Professionally, I've only done car tires, which you generally cannot spin on the wheel with no air - they fit the wheel too tightly. Aligning the stem mark on a car tire requires knowing how the tire will shift as you mount it to the wheel and setting the tire in place correctly before using the machine's iron or arm to press it onto the rim.
  20. Polock
    jayrodoh likes this.
  21. SQLGuy
    Yeah... no thanks.
    Called the shop this morning. Need to bring it down for them to see what's going on.
    My choices are either to ride the bike down so they can take of removing and reinstalling the wheel, or just to bring the wheel. I think I'll do the latter... so I don't have to ride more with that un-round tire, and also so I can bring the old D404, in case the new tire is bad... at the least, at that point, they can swap that tire back on and I won't be without a rear tire for the up to 2 months that an inspection by Michelin will take.
  22. a100man
    Bedford, UK
    35 thou? Less than 1mm - I doubt I'd notice. I don't think my wheels are even that round.
  23. k-moe
    An out of round tire can’t be fixed by balancing it. It will always shake/bounce.
  24. k-moe
    They better be.
    chacal likes this.
  25. SQLGuy
    Maybe I'm misreading the dial indicator, then. It's quite noticeable. The wheel itself ran out more like 5. Too bad there's not an easy way to post the video here.
    Took it to the shop this morning, and their conclusion was that it was not fully seated on the bead. They remounted it and felt it was much better now. I'll probably put the wheel back on the bike tomorrow and see.
    Franz, a100man and k-moe like this.
  26. a100man
    Bedford, UK
    for a cast wheel I guess. Spec for most spoked wheels is about 2mm max (lateral or radial)
    Although 2 mm is actually quite noticeable.
  27. SQLGuy
    Reinstalled the wheel. Definitely looks better just spinning it by hand. Will try it on the road tomorrow.
  28. SQLGuy
    Feels better on the road, but still has some weird vibration around 45 to 50 on the speedometer.
  29. Rooster53
    Well if you are like me you would be thinking "darn, I'm not sure that wasn't there before."
    Maybe the speedo and cable are due for some lubrication?
  30. tj.
    tj. Active Member
    Canada
    Tire issues are a bummer for sure. Some things I've learned over the years of doing my own motorcycle tires...
    If it were me, I would confirm that the bead on both tires are seated properly...since the rear is now correct (assuming), it could have masked an issue with the front.
    Next I would confirm runout in the vertical and horizontal, again in both wheels. Spec on most of the XJ's is 2mm vertical and horizontal. Oddly enough, some are listed as 0.5mm vertical and 1.0mm horizontal, while others are listed 1.0mm vertical and 0.5mm horizontal. Typo in the FSM?...what are the odds ;). Regardless you should check the FSM for your bike.
    After that check how much wheel weight was put on and where in relation to the stem. Nothing in the manuals regarding max wheel weights, but anytime I've added 2oz or more i get concerned. Since Michelin doesn't mark the light spot in the tire with a dot (they are perfect, I guess:rolleyes:) I think the weight should be 180 degrees...ish away from the stem.
    After checking those things and you've found no reason to be concerned, change your tire pressures a little at a time and see how it responds...starting with the pressures listed in your FSM.
    Most manufacturer will ask you to "run-in" a new set of tires, usually 100 miles...it may get better.
    A word of caution, if you decide to use balancing beads of some sort and the tire is found to be out of round, the manufacturer will probably decline a warranty claim. Best to check with Michelin.
    That's all I can think of at the moment...hope you get it sorted.
    Cheers.
