Badly pitted 83 seca 900 fork tubes
Discussion in 'XJ Technical Chat' started by Rasput, Apr 14, 2020.
  1. Rasput
    Rasput Member
    Victory Mills NY
    So I have an 83 seca 900 with inner fork tubes that have some pretty bad spots causing the seals to leak. I'm guessing that my options are to, A- get them re-hardchromed (no idea of anyone who does that in my area), B- replace them (very pricey), or C- swap them with an upgraded front end off of something else (no clue what would be compatible). Thoughts or suggestions are greatly appreciated.
  2. S10gto
    S10gto Member
    Ma.
    Ebay. There is a set on now for under $150 with $40 shipping. Pics look to be in good shape.
  3. a100man
    a100man Well-Known Member
    Bedford, UK
    Dependng on your long-term use.. D- clean degrease and fill pits with super-glue - use a cocktail stick magnifying glass to get detailed view - rub back with 800 grit. Fit gaitors.
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    as , a100man , says , done this several times now, its probably a 3to4 year fix but it works well.
    the first time , take the fork legs off, and keep them as a unit. you only need to work on the "swept part " of the fork tube.
    get a fine file , and gentle file all rust spots , level with the tube. then apply superglue to all rust bits, let dry for 24 hours , then rub down with 1200 grit wet and dry , carefully, until all is smooth with fork tubes,
    I've had great success with this method , no leaks , and passed the yearly mot inspection.
    give it a try.
    stu
  5. bensalf
    yorkshire ,england
    just to confirm, that would be a narrow flat needle file, just on the rust spots.
    stu
  6. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I would think de-rusting the spots before covering with glue would be a good idea too.
  7. Kickaha
    New Zealand
    Done that before, worked fine, still weren't leaking a few years later
  8. Rasput
    Rasput Member
    Victory Mills NY
    So the fork tubes I took off my bike are in very rough shape pitting wise, but the good news is that I have a spare set and I looked them over this morning and there are just a few rust spots. I'm gonna try the superglue method. Maybe I'll do a write up if there isn't one. Thanks for the info guys.
  9. chacal
    Pictures needed! This would be a great "how-to".
