Big problems please help
Discussion in 'XJ Technical Chat' started by gdb619, May 3, 2014.
  1. gdb619
    gdb619 Member
    Albany NY
    My dots weren't lined up
  2. bigfitz52
    It's all in the details. Those dots are a major detail.
    Now that you've had it apart and seen how it works, you can see why turning the shaft clockwise until it stops brings the pullrod up against the back of the pressure plate, so that's where it needs to start from. Otherwise the little lever is just "pawing air" instead of working the clutch.
  3. gdb619
    gdb619 Member
    Albany NY
    Thank u what a difference and I lowered my suspension I like the feel better
  4. mtnbikecrazy55
    So it's all back together and working properly?
  5. gdb619
    gdb619 Member
    Albany NY
    I just finally got everything together it's been one step forward five back so after everything I've done I go to start the bike and I thought the battery was dieing by the sound it makes it makes a click sound but nothing happens I had to get a new clutch basket the one I had broke when I was installing the friction plates so I fully charged the battery nothing can some one please help I don't understand what I did wrong and I really want to it it's been like almost 3 weeks
  6. gdb619
    gdb619 Member
    Albany NY
    Could if be that the teeth on the clutch basket aren't lined up right with the other gear so it's not spinning also does the bolt that holds the clutch basket on have to be torqued or just tightened
  7. bigfitz52
    The NUT that holds the clutch basket on very much needs to be torqued to the proper value and a new tab washer installed to prevent it from loosening. Did you read this? http://xjbikes.com/Forums/viewtopic/t=29541.html It applies to your bike as well, your clutch is just simpler is all.
    I'm not quite understanding why you think that the clutch is causing what sounds like a dead battery.
    Do you think that somehow the clutch is keeping the motor from turning over?
  8. gdb619
    gdb619 Member
    Albany NY
    Yeah I don't thing I lined up the gears right
  9. gdb619
    gdb619 Member
    Albany NY
    I figured out what was wrong fixed it does anyone know the torque spec for the clutch basket bolt for a 82 maxim 650
  10. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Which XJ are you talking about?
  11. gdb619
    gdb619 Member
    Albany NY
    The maxim not the Seca lol
  12. gdb619
    gdb619 Member
    Albany NY
    OK I have a question about rotating the shaft how do I do that I tried with channel locks and I couldn't get it to spin I didn't want to break it either
  13. bigfitz52
    Rotating what shaft? The crankshaft? The clutch release shaft?
    Your torque spec for the clutch hub nut is 52 ft/lb.
  14. gdb619
    gdb619 Member
    Albany NY
    Where it says this part THEN, rotate the top of the throwout shaft CLOCKWISE (viewed from above) until it STOPS, and reinstall the lever, return spring and clip
  15. ColoradoDan
    ColoradoDan Active Member
    Longmont, CO
    The shaft will rotate with your fingers until it engages the clutch. Was just working on mine last night.
    Take the spring loose first.
  16. gdb619
    gdb619 Member
    Albany NY
    I just did a test ride and it still doesn't feel right It's hard to kick it in gear
  17. ColoradoDan
    Longmont, CO
    Was it WELL warmed up? Even with my latest adjustment, mine is clunky until the oil is hot - normal of course on wet clutch
    Also, the adjustment I did this year was to dial it counter-clockwise another spline back so the little pip on the arm is just to the (visual) right of the arrow. The closest to lined up I could get before was just to the LEFT instead of spot-on.
    It really helped shifting. This is the post that gave me more info...
    http://xjbikes.com/Forums/viewtopic/t=44555/
