Brake rub.. 650 seca
Discussion in 'XJ Technical Chat' started by Cyfer, Apr 13, 2016.
  1. Cyfer
    Cyfer Member
    CA
    Hi guys, I just finished putting my front wheel back on the bike with new tires and brake pads. For some reason, the caliper is hitting the brake rotor.. I took the caliper apart again and the pads are sitting correctly.. I didn't have that problem before and the right caliper (Canadian Seca with dual front rotors) seems spaced just fine. I'm thinking it might be the small spacer that sits on the right side of the wheel and the fork that isn't seated properly and it's causing the wheel to be a few mm off centre. Any ideas? Here's a pic of the rotor and the bike in question!
    Rotor rubbing:
    Right side of the bike - brake sitting well - small spacer I'm referring to:
  2. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    I recently rebuilt my brakes, too. And I came across this problem.
    This is likely a stupid question, but I'll ask it anyways.
    Did you try compressing the brake lever until it becomes firm?
    Oh, and if not, did you try just pushing it over?
  3. XJ550H
    speedo hub properly alined all axel spacers in correctly
    did you grease the pin the halves slide on11:20 8:17
  4. Cyfer
    Cyfer Member
    CA
    Could very well be the speedo hub - Should the female receptor piece be parallel to the ground pointing to the rear of the bike or perpendicular to the ground pointing up?
  5. XJ550H
    there is a tab on speedo hub that goes into a slot on the fork tube
  6. XJ550H
    the spacer you are talking about goes into the seal and rests on wheel bearing .
    are both washers on mounting bolt of caliper on outside if fork should be
    you are missing the washer that goes under the axel nut
  7. Cyfer
    Cyfer Member
    CA
    I figured it out last night and I figure I should post this is anyone comes accross a similar problem. While the wheels and brakes were off, I took off the front forks off to paint them. I had marked their height as to where they should go but it seems that when I reinstalled I must of been about 1 or 2mm off.
    The axle bolt that went through and through would still align in the holes but the small shift in the suspension was causing the whole assembly to be out of square. This was causing the rotor to be slightly angled towards the fork and rob me of the 2mm I needed to fit the brake caliper.
    I slid one side down while the wheel was in with the axle bolt loose and manage to align everything perfectly!
    XJ550H likes this.
  8. DenCon509
    DenCon509 Member
    Central Washington, USA
    IIRC, when you have loosened/removed anything at the front end, upon reassembly, you should loosen everything. Then - starting at the bottom - tighten it back up.
  9. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Very close. Tighten a bit as you go up until everything is snug to allow everything to naturally marry (it'll take a couple times) then do a final torque starting at the beginning. This way any binding will be easily noticed.
    Gary H.
  10. k-moe
    Don't forget to bounce the front end just before snugging it all up tight to get it all to settle in.
    DrewUth likes this.
  11. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
