" brake" warning on odometer wont reset.
Discussion in 'XJ Technical Chat' started by Rodney Brown, May 11, 2020.
  1. Rodney Brown
    Rodney Brown Member
    Bronx, n.y.
    Have a " brk" warning on my odometer. Front brakes were shot so I put new pads , bled the system. Brakes fine now. But the " brk" indicator is still showing. How do I make it disappear? Thx.
    that warning is brake fluid level warning.
    add fluid
    could be the float has failed or come unplugged.
    check connections
    I think chacal has replacment "floats" for your bike but not for the maxim MC.
    HCP3025 OEM master cylinder FLUID LEVEL SENSOR. This is the complete low-brake-fluid sensor switch assembly: float, post, lead wires and connectors. For all XJ750 Seca front and XJ1100 rear master cylinders.
    also sells a widget you can plug it to shut off light.
    HCP19573 Aftermarket ADAPTER WIRE for low-brake fluid sensor bypass. Since the 1983 master cylinder has no provision for the low-fluid sensor, you need to by-pass the sensor so that the computer is fooled into thinking there is plenty of fluid in the reservoir.
  3. Rodney Brown
    Rodney Brown Member
    Bronx, n.y.
    she's full of fluid. I'll check da connections. Perhaps a battery unplug will reset it? ( Like a car)
  4. Cbunn01
    Cbunn01 New Member
    Columbia, MO
    How does one bypass the sensor?
  5. Franz
    XJ550H has not been seen since July 2023.
  6. Simmy
    Anybody know what happened to him?
    He was a valuable contributor
  7. Franz
    Yes he was.
