Break-in oil?
Discussion in 'XJ Technical Chat' started by Matt Rain, Sep 20, 2017.
  1. Matt Rain
    Matt Rain Member
    Toronto, ON
    So I've now put 200 miles or so on my rebuilt '89 Radian engine, taking care to vary RPM and avoid lugging the engine.
    While shopping for a new clutch cable today, I noticed that Maxima is selling a "Break-in oil", 10W30 in weight? Should I consider using that or is it too late?
    https://fortnine.ca/en/maxima-performance-break-in-oil
    Also... what's a break-in oil?
    (For the record, I'm using Rotella T 15W40 right now.)
  2. Jetfixer
    Generally break in oil has a higher zinc content that regular oil. Your probably ok as is , I used this on one of my VW engines did not notice a bit of difference .
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
    When I bought my 83 XJ550 brand new, I'm sure it just had the spec oil from the factory. I do recall the dealer had me change it at a shorter interval the first time, and to vary speeds for the first 1k as you doing.
    Currently, I use the same Rotella you are using.
  4. XJ550H
  5. Matt Rain
    Matt Rain Member
    Toronto, ON
    Interesting, thanks. This is being sold by a motorcycle-specific online shop, weird.
    Ima stay put and just refill her with Rotella at the next change.
  6. Oldmansin
    Oldmansin Member
    Nc
    All, I repeat ALL engines leave fine metal particles in the oil after being rebuilt. No matter the oil used, that's why the short change period on the initial oil. On cars I always used cheap oil that was in spec for initial startup, let the engine idle for about twenty minutes then changed the oil and filter. I would cut open the filter to inspect the metal to make sure it wasn't major, then change it again after about 200 miles with good oil after. If you have a spin on filter putting a strong magnet on the filter for initial is a good idea.
