Breather gaskets?
Discussion in 'XJ Technical Chat' started by SecaRob, Mar 5, 2009.
  1. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Some of you may have seen my other bling bling thread where I have been polishing the cases on my Seca. Had pulled the gearshift cover off and picked up a new gasket for it from our favorite parts guy but neglected to pick up the 2 smaller ones for the internal breathers.
    The old gaskets for the breathers came off perfectly but feel pretty rigid. With 70 degree temps forcasted I am considering reusing the old gaskets. My question is am I running to big of a risk using the old ones or should I just suck it up and forget about riding this weekend?
    thanks all
  2. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I don't see any problem with re-using the old gaskets if they are still in good condtion. Being it is rigid or brittle won't be an issue if you use a good high temp RTV silicone sealer during installation. I've done it more times than I can remember and never had a leak problem. I always followed the instructions and let the RTV setup for 5 minutes before mating the surfaces back together and only tighten the bolts finger tight. Then let it sit for 1/2 hour before the final tightening process to get a good seal. That always seems to work to re-seal an old gasket.
    I like to let it setup over night if possible before riding, but I have been known to only let it sit for a few hours before running it. I'd say let it setup for atleast 2 hours before running it.
    I did the same thing with my valve cover gasket last year when I set my valve clearance and don't have any leaks yet with the old gasket still in there. Go for it!
