Broken petcock, fuel line pulled metal piece out, any suggestions?
Discussion in 'XJ Technical Chat' started by Dr. Awesome, Oct 24, 2016.
  1. Dr. Awesome
    Dr. Awesome New Member
    MN
    Hello, I was messing around taking the tank off on my 82 XJ750 Maxim and when I went to remove the fuel line (custom farmer job if you can't tell) it pulled right out! Does anyone know if this is repairable? I could probably JB Weld it, but I am looking to see if there is any other suggestions that are a little more permanent. Is this thing press fit in? I was told (by my uncle's landlord) it was a new petcock, it did hold and pass fuel as far as I could tell, so if I could just get the piece back in it would be great.
    Thanks!
    That part is a press-fit. Press it back into place. If it is easy to remove then a light smear of 2-part epoxy on the outside of the brass nipple is fine; a bearing retaining compound would work as well, and be less messy.
    My prefrence however would be to replace the petcock with the correct vacuum-operated petcock, as originally supplied by Yamaha.
    The short story is that was a new petcock; a cheaply made one.
    Stumplifter likes this.
  3. Dr. Awesome
    MN
    Sounds good k-moe, I'll look into a new one. I'll probably epoxy this one until I get the tank all disassembled for painting. Just got a full gasket kit, so I'll be taking it all apart anyway. Thanks for the response!
  4. Jetfixer
    Look an eBay for a used one, get a rebuild kit from xj4ever should be good to go.
  5. k-moe
    I have to ask; what is the dubiously spliced/duct taped wire hanging over the carbs and down the side of the engine?
    Is it a wire, or maybe a copper tube for an oil pressure gauge?
  6. Dr. Awesome
    MN
    Oh I was hoping nobody would notice that! My uncle did that (check my profile for a quick description), it is the fuel gauge wire that I assume is spliced, covered in a piece of tube, and RTV'd to seal it. Don't worry, it's on the list of things to fix...
  7. XJ550H
    rtv can be corosive to wires
