carb diaphragm replacement tutorial?
Discussion in 'XJ Technical Chat' started by to the max, Mar 31, 2024.
  1. to the max
    to the max Member
    Akron, Ohio
    I could've swore I saw a tutorial on here somewhere showing the process of replacing the diaphragm, but can't find it now.
  2. BallAquatics
    BallAquatics Active Member
    Ohio, USA
  3. to the max
    to the max Member
    Akron, Ohio
    Thank you for the reply but I bought the ones that you would re-install the plastic rings. Should've done a little more research before I ordered.
