CarbTune maintenance
Discussion in 'XJ Technical Chat' started by Xjrider92117, Mar 23, 2019.
  1. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Is there any maintenance that ever needs to be done to the the carbtune Pro? Besides replacing the hoses.
    Nope.
    Maybe wipe the dust off of the case occasionally.
    Jetfixer likes this.
  3. XJ550H
    Q. My dial gauges always need recalibrating, is this necessary on the Carbtune Pro?
    A. No. The components of the Carbtune Pro are matched during assembly at the factory and will not need any recalibrating. They work on a different principle to dial gauges.
    Q. What happens if the Carbtune gets dirty or greasy inside?
    A. The Carbtune can be dismantled for cleaning and this is described in the instructions. It is very simple to do.
  4. Jetfixer
    Bought mine last year , great product.
  5. Xjrider92117
    San Jose Ca
    I didn't think so. The reason I asked was because today I was trying to sync my carbs at around 1200 rmp's and not one of the rods were moving at all. I then turned up the idle to about 2500 rpm's and the rods started to go up maybe an inch.
    I took the carbtune off and flipped it upside down and the rods barely moved. I gave them a little shake and they started to come down a bit flipped it back over and very roughly they came back down.
    I kind of thought that they could've used some lube or something. Maybe I'm thinking about it to much. They rarely get used...
