Check my valve shim math
Discussion in 'XJ Technical Chat' started by maverickbr77, May 22, 2011.
  1. maverickbr77
    maverickbr77 Member
    Lowville, New York
    1981 seca 750
    Intake
    Cylinder 1 clearance .305 shim 285 need shim 300
    Cylinder 2 clearance .330 shim 285 need shim 305
    Cylinder 3 clearance .127 in spec shim 275
    Cylinder 4 clearance .203 shim 285 need shim 290
    Exhaust
    Cylinder 1 clearance .152 shim 270 need shim 265
    Cylinder 2 clearance .152 shim 275 need shim 270
    Cylinder 4 clearance .127 shim 270 need shim 265
    Cylinder 1 clearance .152 shim 265 need shim 260
    Also where is the best place to find shims for these.
  2. wizard
  3. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Numbers look good.
    Chacal has them.
    If you have a generous Yami dealer near you they may swap them out for ya.
  4. BillB
    BillB Active Member
    Tulsa Oklahoma
    Might be a generous forum member who can send you the right ones.
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I'd be little suspect of something, when 2 of your intakes measure .30
  6. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Just had the engine apart valves and cams look good. Anything else I should be looking at.
  7. waldo
    waldo Member
    San Jose, Ca. 95125
    Maverick did you type the intakes in wrong? When the valves wear we use thinner shims you are going thicker, did you change the cam?
  8. maverickbr77
    maverickbr77 Member
    Lowville, New York
    those are the correct numbers
    here is everything I can think of on it.
    No changes to the valves or cams, everything torqued to spec on reassembly, 18k miles, taken apart and together following haynes, didn't check before tear down, torn down due to seized rings on cylinder 2 or 3 (can't remember right now which), only spun by hand for timing check and clearance measurements since reassembly with no problems, gaps checked with my shiny new feeler gauges.
  9. waldo
    waldo Member
    San Jose, Ca. 95125
    PO must have done it then did you ride the bike before you had to rebuild top end?
  10. maverickbr77
    maverickbr77 Member
    Lowville, New York
    nope I haven't run it at all yet. came with carbs off. Po got scared when he saw one of the slides seized in the carb.
    Ps. I knew the bike had some issues that is why I got it. I wanted something to tear apart and see if I could fix it.
  11. waldo
    waldo Member
    San Jose, Ca. 95125
    Looks like your on the right track PO probably screwed up the valve shims on the intakes and bike would not make any power if it would even run at all. Good Luck
