clean carbon deposit?
Discussion in 'XJ Technical Chat' started by Juniorglide, Dec 6, 2015.
  1. Juniorglide
    Juniorglide Member
    Lasalle, QC
    Hi everyone. I had to remove the exhaust headers because my collector needs attention ( welding).
    I took a peek inside the exhaust ports out of curiosity and I noticed a lot of hard carbon buildup on the port rim.
    Can this be removed safely? I'm thinking this is somewhat restricting the flow of gases.
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Have you removed the exhaust gaskets from the ports?
    Gary H.
  3. k-moe
    And bofore the usual reply of, "There are no exhaust gaskets on this bike" Yes there are.
    Once you pull the gaskets out you should only see an aven film of carbon. You can use a rag soaked in the solvent of your choice to wipe it out of you choose, or just leave it since it's not restricting flow (unless of course you see something that's more than a thin film).
  4. quebecois59
    pictures?
  5. Juniorglide
    Juniorglide Member
    Lasalle, QC
    No I haven't. I only removed the pipes. The carbon buildup would be on the gaskets?
  6. rocs82650
    Middle Tennessee
    What you might think is build up might be the gasket.
    Gary H.
  7. Juniorglide
    Juniorglide Member
    Lasalle, QC
    pictures are coming.
    Ben (xj750)
  8. Juniorglide
    Juniorglide Member
    Lasalle, QC
    quebecois59 likes this.
  9. rocs82650
    Middle Tennessee
    The valve stem seals are leaking and the head gasket has blown. The copper exhaust gaskets are in there. How's your bike running?
    Gary H.
  10. Juniorglide
    Juniorglide Member
    Lasalle, QC
    The bike runs very well, pulls very hard, good acceleration. I rode this afternoon and all was well.
    Is the bottom of the hole deposit for real is that the gasket shape?
  11. rocs82650
    Middle Tennessee
    No. The gasket is in front of it. It's the goldish bronze ring. Let's see what other members say about the build up on the valves and guides.
    Gary H.
  12. k-moe
    The carbon buildup is pretty normal, though I do agree about the leaky guide seal, and the tell-tale powder-white at the head gasket also makes me strongly suspect a head gasket failure.
    The squared-off lip you see along the bottom of the exhaust port is the just the shape of the port; it's not excessive buildup. There will be some carbon buildup along the back of the gasket as it's slightly narrower than the exhaust port.
  13. Juniorglide
    Juniorglide Member
    Lasalle, QC
    Thanks everyone. I guess this winter I'll have more to do than wipe off some carbon deposits...
    Ben
