EURO Pattern questions - Premature post - Unless problems...
Discussion in 'Hangout Lounge' started by Metal_Bob, Nov 16, 2010.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    So I got my cheap AutoPal Euro lens, reflector, bulb (x2) and rubber boot today.
    http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT
    I know I've never used a Euro headlight before but is it defective, upside down bulb or just me?
    I have not take a ride yet (maybe later tonight BRRRRR) but there seems to be ZERO light pointing down (lower half of the lens) and a slight extra bit upper right (for street signs).
    The (extra) bulb I got also seems to have a reflector near the tip that may actually be causing the 1/2 lighting.
    Am I crazy or did I get improper bulb/lens? (Yes I bought the EURO style on purpose).
    [​IMG] [​IMG]
    FYI: The light on my house is only a few feet away from the bike - I know not the best test...
  2. iwingameover
    iwingameover Active Member
    Re: Defective, upside or just no use to Euro Light Pattern?
    Maybe aim it down?
    That looks high to me.
  3. Metal_Bob
    Bourbonnais, IL
    Yes I still need to fine tune the aiming, but what about the 1/2 reflector on the bulb and the lens only illuminating light on the top 1/2.
    Is that normal for Euro/H4 ??
    I wasn't planning on riding tonight, but I might go out to at least tweak the aim.
    EDIT: Quick google search shows bulbs with the 1/2 reflector inside. So I guess that part is normal. Should the reflector in the bulb be blocking light up or down??
    EDIT 2: Maybe I was to quick to post w/o checking it out further away from a wall. Without an actual night ride, the bulb does seem to be illuminating the road. Though there is a definate amount of light pointing up and to the right (for street signs?). So, unless my concerns were valid, ignore my post for now :oops:
  4. Polock
  5. bigfitz52
  6. Metal_Bob
    Bourbonnais, IL
    thanks.
    with my Windjammer IV it is very easy to adjust up/down but have to remove headlight reflector totally to adjust left/right :(
  7. day7a1
    day7a1 Member
    San Diego, CA
    The euro lights are supposed to have that rightward, upward "wink", and you are correct, it is for street signs.
    BTW...metal bob...YOU POST A LOT!
    :) Brother, I remember when you were still a Biker wannabe, and you are already red lining? I need to step my game up, I guess.
  8. Metal_Bob
    Bourbonnais, IL
    I may post alot, but I am learning and trying to help others when I sorta know what I'm talking about :)
    It doesn't help I don't have any "bike" friends (yet) to ask common questions.
