First post(need good news too)
Discussion in 'XJ Technical Chat' started by guywithbike, Mar 20, 2006.
  1. guywithbike
    guywithbike New Member
    arkansas
    ok.
    hello people this is my first post, and i need some help.
    i do belive i have a 1982 XJ750RJ -the vin is-jya15r0d2cad09223.
    and i need to know if a wire harness from a 1980 xs650 special will work on it? and if not could imake it work?
    Thank you.
  2. SnoSheriff
    MB, CAN
    Here are the Wire Harness Assembly part numbers pulled out of the Cross Reference:
    XJ750RJ 1982 XJ750R Seca: 5G2-82590-50-00
    XS650SG 1980 XS650S: 3G1-82590-51-00
    XS650G 1980 XS650 Special II: 3G0-82590-50-00
    It looks like the part numbers are different but I don't know what makes them different and if you can make it work. Maybe someone knows what these prefixes mean :? :?:
    The following bikes seem to have the same wiring harness assembly:
    XJ750RH 1981 XJ750R Seca
    XJ750RK 1983 XJ750R Seca
  3. Robert
    Hard to say without the schematics. If you have copies of both, do a little comparing. I don't have access to the XS schizmo in particular. If you need a comparison done, shoot me the pdf files.
  4. Joel07
    Joel07 Member
    Durham, NC, USA
    I would have to assume that the XS650 wiring harness is quite a bit different being that it's a 2 cylinder rather than 4 cylinder.
  5. guywithbike
    arkansas
    ok thanks for the replies.
  6. guywithbike
    arkansas
    ok can someone tell me what year and model will fit.
  7. Nick
    Nick Member
    Vernon, BC Canada
    Sno already gave you the following info:
  8. guywithbike
    arkansas
    ok sorry late at night when i looked at it.
  9. Lawnie
    Lawnie New Member
    Central New York
    Hi guywithbike,
    I would like to help ya out to get your bike going - Warm weather is coming - Gotta be ready to ride!
    I have a wire harness for a 81-83 Seca XJ750 for sale.
    Send me an email to my regular email address below and we can go from there!
    Lawnie
    EMAIL: roadtoad@bluefrog.com
  10. guywithbike
    arkansas
    ok i will in a few minutes.
    thanks
  11. guywithbike
    arkansas
    hello all.
    i finally got a wire harness for my xj750j maxim. the wire harness is from a 83 xj750, and it all went together good, but i dont have spark when it cranks but when i push the killswitch it sparks, are there any sensors that would stop it from starting, i have wired the kickstand swicth so its not the problem. and there is a exta relay on the right side of the harness toward the top that clicks the same way the ignition switch does.
    thanks.
  12. guywithbike
    arkansas
    oh and officerXJ the carb shaft seals worked perfect thanks.
  13. srinath
    srinath Member
    Charlotte NC by way of Bay area CA
    I have heard that the first 3 characters of a part number in the yamaha convention is the model that part was first used on. I dunno how accurate that is though. if one small change was made for one particular model, I believe it may have the same everythign else but a different prefix. no idea what that means.
    Cool.
    Srinath.
  14. Robert
    It occures to me that you should verify the function of both your side stand relay and your starting circuit cut-off relay before proceeding. The outline of how to do this is covered on page 245 of the Haynes manual. Note: the side stand switch and neutral switch must both be in the correct position for the relay to function on your model. Good luck.
  15. guywithbike
    arkansas
    the switch is pushed in (bike is on work stand) and in nuetral. any one know a good way to rewire ignition wires, PO put high watt fog lights on it and melted everything so i cant use old harness for guidence, any way to wire coils to cdi and kill switch?
    thanks.
  16. RickCoMatic
    You might want to examine (or disconnect for testing purposes) the Neutral & Side Stand Relay. This relay is unlike other standard Yamaha relays. The two poles controling the signal voltage opening and closing the safety circuit, are postitoned differently from the other relays on the bike.
    If a standard relay has been used to replace the safety relay ... the circuit is reversed. Pulling the clutch lever normally allows the safety relay to close and the bike may be started with the clutch lever pulled. This becomes OPPOSITE if the relay is the incorrect one.
    Having the incorrect relay replacing the safety relay actually allows the start motor to engage WITH THE CLUTCH LEVER RELEASED -- AND THE BIKE -- IN -- GEAR.
    An easy test to determine if the wrong relay was used to replace a safety relay is: The bike will need to actually be in Neutral for the Starter to engage and start the engine.
    And, the very dangerous situation of the Starter kicking-in ... with the bike IN GEAR -- with the clutch lever RELEASED and the START Button pressed.
    The relay is below the fuel tank -- under the center tube of the frame -- closest to the fuel tank bolt-down, just behind the turn signal cancellation module.
  17. guywithbike
    arkansas
    hey thanks the info, but i have tried everything so i need a wire harness for my specific model, and hope i havent burnt up anything.
  18. Robert
    Sure, new wire and a soldering gun are in order, but it can be done nicely. You may want to source a used harness rather than go through the bother. Looks like your headed the right direction already. I can rebuild an old harness so long as I have a fairly intact harness to begin with. Length and component placement must be a known factor in order to build a decent harness. If you are of a mind, I could wire in your needs rather easily if you want to ship it out here and cover parts.
  19. guywithbike
    arkansas
    hey thats nice of ya, so u could get the seca harness to work with the maxim? But the maxim harness looks like a lawnmower hit it.
  20. Nick
    Nick Member
    Vernon, BC Canada
    Sorry I'm confused :?
    Have you confirmed your model of bike yet? In your first post it's a seca model "RJ" then later in posting it's a maxim "J".
    I couldn't find the vin number in the XJCD vin # listings and from another list of information the closest I could come up with suggests it maybe a 1985 maxim X
    XJ700XN 1985 Maxim X 700 JYA1AA US/UK
    XJ700XNC (Ca. only) 1985 Maxim X 700 JYA1FJ00 US/UK
    I would confirm which model you have before buying any more wire harnesses.
  21. Robert
    Here is the rub. It is much easier to convert a Seca harness to a Max, not vice-versa. The Seca's harness is loaded with all the connections for computer goodies and such but can be set up for a Max without any trouble. The Max harness is a bit more stripped down, one would have to add a bunch of wires and a few connectors to get it up to Seca duty. Lawn mower eh? As long as all the connectors are there and the wire lenght can be determined, it is do-able. Pictures?
  22. guywithbike
    arkansas
    ok ill get pics, and the rj thing was before i called dealer to find out for sure. the vin came from title so it is a xj750j maxim 1982 (dealer reference if they know what there talking about.). yeah i do need to stip down some wires to fit my model.
    yeah lawnmower, po had harness on ground forgot about it and decided to mow yard after i got bike. they had salvaged harness from mower blades put it together and it bike ran but not a whole lot of things worked on it.
  23. xjchoppa
    xjchoppa Member
    Oklahoma City, OK
    My bike will turn over with clutch in or out in neutral or in gear kickstand up or down...doh...and none of the above will put juice to the coils.
  24. RickCoMatic
    Hey guys:
    I spent 5-minutes looking for a good used harness online.
    Here's one good deal I found.
    http://www.motorbiketoronto.com/items.j ... artno=188-
    Got to be a WHOLE LOT LESS complicated fitting a completely good, used wiring harness, for this kind of money ... than firing-up the soldering iron and trying to resurrect one run-over by a lawn mower.
    Call a Priest for the sliced-'n-diced one. Bite the bullet and buy the trouble-free used one ... and get the job done -- right, please.
  25. guywithbike
    arkansas
    lol calm down ppl. i did not know about the motorbike site, and its $90.00 more than a donor harness i got from e-bay. but it does say complete on the motor bike site but what make. xj,rj,jk??. so if robert is willing to redo
    the 2 harnesses i have for a little bit of time why not?
  26. Robert
    Rick has a point. There is a time when biting the bullet is the best course of action. I'm not sure this is one of those times but I would let other seasoned people help me make that call if I didn't know very much. Your pictures should give me all the info I need to make that determination. PM'd you details, waiting to hear from you.
  27. guywithbike
    arkansas
    Hey ricko i hate letterman.
    (Sometimes I think the posts to XJBikes are written by the same comedy team that writes for David Letterman.)
    (And get a load of this one ... another guy actually runs-over his
    whole
    > wiring harness with the lawn mower. He can get a perfectly good
    used one for
    > 80-Bucks ... but, decides that spending a lifetime soldering the
    one he sliced
    > and diced is a better idea.
    > You can lead a thirsty horse to water ... but, you can't convince
    him that a
    > perfectly good used one would be better than soldering all-week to
    keep "The
    > one that came with the bike"
    > Go figure.)
    later ppl, guess ill find help else where.
  28. HooNz
    HooNz Member
    The horse might be smarter than the leader thinks , maybe the water taste's like crap , or it can smell something just pissed in it?... :) which the smart? leader can't smell :). so looks at leader drinking and DUH!.
  29. chacal
    "wisdom sounds foolish to fools."
  30. HooNz
    HooNz Member
    A fool is aloof.
