FJ600 - Trouble starting.
Discussion in 'XJ Technical Chat' started by RonniN, Jan 10, 2022.
  1. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Works in a pinch, high density.
  2. RonniN
    RonniN Member
    Denmark
    I got gasket paper, but the fuel connector is leaking, so i anyway need to order parts. :)
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    those fuel rail "T" pieces are a real pain, and rarely reseal when they have been removed, why they didnt put "O" rings on there i will never know , so i put some very thin section "O" rings on myself ,and pushed them in there with a thin blunt bit of plastic, and the seals hold fine, dont know the size or number of them just now, but could find out tomorrow if you like, as the "T" pieces are not cheap
  4. RonniN
    RonniN Member
    Denmark
    Thank you for the reply, unfortunately i already ordered a new Fuel T, 30 Euro.. :(
    I will order one from china also, it comes with orings, so nice to have in stock for the future, and a lot cheaper than a Yamaha OEM part.
  5. hogfiddles
    I don’t bother to reuse the original Mikuni ones. They are always worn out. I’ve only had ONE that was still good. I replace them with the brass ones with the double O-rings that LEN carries.
  6. bensalf
    yorkshire ,england
    yeh, that would be a good plan, but postage and import costs would probably make them dearer than original ones
  7. bensalf
    yorkshire ,england
    RonniN, do you have a link or something, to the T piece from china you are ordering, cant seem to find them on ebay
  8. RonniN
    RonniN Member
    Denmark
  9. bensalf
    yorkshire ,england
    thanks RonniN, i ordered one last night, around £9 , GBP :)
    RonniN likes this.
  10. a100man
    a100man Well-Known Member
    Bedford, UK
    I 'think' that as a makeshift solution I've wrapped with PTFE tape in the past to make a seal..
  11. RonniN
    RonniN Member
    Denmark
    I was thinking about doing something similar, but it is fuel, so i dont want to risk it leaking while riding, seat heat could be nice, but still. :)
  12. RonniN
    RonniN Member
    Denmark
    And now its running on 4 cylinders, but has developed a squeaking sound, maybe a leak somewhere, nothing to be heard when just cranking the engine, but when it fires something squeaks.
  13. a100man
    Bedford, UK
    I'm going to check if I can see signs of the tape. If I have used it, its been there for over 4 years..
    RonniN likes this.
  14. RonniN
    RonniN Member
    Denmark
    Noise is gone, it was an intake leak, not sure why the new gaskets caused a leak, but it was fixed with a thin layer of sealant on both sides of the new gaskets, now 4 cylinders - and one stop closer to a MOT. :)
    Timbox likes this.
