front turn signal ground
Discussion in 'XJ Technical Chat' started by nillawaferjam, Aug 3, 2017.
  1. nillawaferjam
    nillawaferjam Member
    Elkhart in
    Do the front flashers have a wire ground or are they just grounded to the frame?
    depends on the bike easy way to tell is if you only have 1 wire coming from bulb holder and when you remove the lens you see a braided copper strap about 1/8" wide from bulb holder to blinker housing.
    I have a 83 750 like this and the older 650 can be like this.
  3. XJ550H
  4. nillawaferjam
    Elkhart in
    Thanks! I can't figure out the turn signal system that's on my bike (80 650 maxim). I think I'll just put an entirely new system on, run my own words and stuff and use the original switch haha i can't do the whole chasing wires thing
  5. hogfiddles
    What is the problem with yours? It may be a simple fix before going and redoing everything
  6. XJ550H
    the blinker is clamped to the mount on the bike and sometimes has to be removed and cleaned you can test this with a jumper wire from ground to the blinker housing
  7. nillawaferjam
    Elkhart in
    So the guy I got the bike from repainted it and took everything off without labeling anything. The rears were pretty easy to figure out. I hooked those up but they would only stay on constant. I assumed the circuit needed more resistance so I tried every possible configuration with the front leads to open connectors behind the headlights. None of them worked. All the bulbs are good. the connections on the blinker Relay under the tank are hooked up. The main wiring harness got left on for the paint job too.
  8. k-moe
    Have you taken the cover off of the signal relay and cleaned the points?
    Is your battery fully charged?
    Are you using 27 watt bulbs?
  9. nillawaferjam
    Elkhart in
    Looks like I have 23 watt in the front, it looked like 32 watt bulbs in the rear. I'll try some 27 watters
  10. nillawaferjam
    Elkhart in
    It was the wire connections to the contractors the switch they were broken off. I don't know how that gave me power in the rears but not the fronts.
  11. nillawaferjam
    Elkhart in
    The best part is I tightened the valve chain tensioner while I was at it because the bikes sluggish at high rpms and now it's clacking really bad even with the tensioner bolt back to how I had it originally
  12. hogfiddles
    Done your valve clearance check lately?
  13. nillawaferjam
    Elkhart in
    Maybe 100 miles ago. Late May ish
  14. nillawaferjam
    Elkhart in
    When I open the throttle up, even in 2nd but super sensitive in 4th and 5th, it's like hitting wet grass with a lawn mower.
