Hello from Sydney AU
Discussion in 'Hangout Lounge' started by Paulo Hanashiro, Jan 14, 2018.
  1. Paulo Hanashiro
    Paulo Hanashiro New Member
    Sydney, Australia
    Hi. I’m Paulo from Sydney-NSW Australia.
    I just bought a XJ900R 1983. Bike is not running and I have no idea of its real conditions. It was sort of a barn find and no one could give me detail about bike conditions when it was parked in the past nor for how long it was stored.
    Just downloaded the Haynes manual and I’ll start basic clean up this week.
    Any suggestion in where to start and most important, where should I start as my initial checks?
    Thanks in advance.
  2. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    You'll want to check pretty much everything. For safety's sake, the tires and brakes hoses should be replaced. There's a manufacture date on them, and their functional life is about 5 years. Barn bikes have usually been stored longer than that! A full service on the brakes is a good idea including master cylinder and caliper cleaning/rebuild. The carbs will probably need some love too.
    http://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/
    Also, some reading material:
    http://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/
    wifflebat and Stumplifter like this.
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Oh no! You meet MattiThundrrr. He is the Thundrr from down under.;)
  4. Paulo Hanashiro
    Sydney, Australia
    Thanks MattiThundrrr and lostboy.
    I’ll start my readings with the recommended above.
    What about the engine? After changing oil and filters, What should I do before cranking it for the first time?
  5. Toomanybikes
    Tsawwassen bc
    Remove spark plugs and left engine cover and turn engine by hand.
  6. hogfiddles
    Ummmm... He's on top, not down under
  7. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If it has been sitting for a long time I would check and make sure the oil is reasonably clean and remove the plugs and look into the cylinders to verify there is no rust. Then I would put a couple of teaspoons of Marvel Mystery Oil in each cylinder and turn it by hand several turns and let it sit for several days while you attend to other issues. It may help free up any stuck rings.
  8. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Just out of curiosity did you do a vehicle registration check, I think you can find out when it was on the road last by doing that.
  9. Paulo Hanashiro
    Sydney, Australia
    hi Maxim-X
    I found it was registered till 2015.
    But this don’t tell much about when the bike was parked as I know people that never ride their bike but still pay for registration every year. :oops:
    Thanks all for the insights.
  10. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard.
    Gary H.
  11. Paulo Hanashiro
    Sydney, Australia
    Thanks Gary
  12. Paulo Hanashiro
    Sydney, Australia
    Hello to all!
    I removed the spark plugs and was able to turn rear wheel in 5th gear.;)
    Bad news is that I noiced some unusual textures in the engine and when I removed what I guess was epoxy filler with a dremel I found a broken cooling fin and a missing part of engine case (looks like someone had an accident)
    A1ED4ECA-A3FE-4FFD-8637-806E0BE231F4.jpeg 00502BF7-65BB-4B87-85DB-B9121994E4D5.jpeg
    Apart of this, engine looks good in visual inspection.
    What would be the best option: Fix this engine or try to find a replacement? Pros and cons for the above options?
  13. Jetfixer
    Welcome aboard , Go to the upper right corner of the page and click on xj4ever , here you will find the information overload hour and all the new parts you will ever need ,and they will be the correct parts . Chacals service is awesome . As to your engine well find a competent tig welding service they might be able to repair the cooling fin . Good luck
