Help! Electrical system is dead!
Discussion in 'XJ Technical Chat' started by Gypsy, Jun 13, 2020.
  1. Gypsy
    Gypsy New Member
    Bewdley, Ontario, Canada
    Hi all. I just purchased a 1986 Maxim x 750 last week. It had been in storage for a year or so according to previous owner. Bike was running o.k for a few days, some gas fumes in the oil ( Carb needs cleaning I suspect). Recently, I started the bike it ran for about 30 seconds and I think I heard a slight "pop". Everything died. No lights, no green neutral lamp indicator, nothing. Zero. Zilch. Nada.
    I checked the battery - 12.54 volts.
    Checked the selenoid - 1 side 12.54 volts, other side zero with key off.
    1 side 12.54 volts, other side zero with key on.
    Removed the ground wire and checked the selenoid again-
    1 side 12.54 volts, OTHER SIDE 12.54 VOLTS KEY ON.
    I replaced the ground wire- same deal.
    A few hrs later, I turned the key and voila! All lights are on! Turn the key to start, hit he starter button and... Dead. Everything gone. Again. This has happened twice.
    I really dont know what to next except clean all connections. Or perhaps the TCI is not reading enough voltage from the battery? A new battery?
    Any input would be appreciated.
    Little John
  2. Toomanybikes
    Tsawwassen bc
    Contacts in the back of the ignition switch or main fuse holder is failing
    XJ550H likes this.
  3. XJ550H
