how do I screen capture?
Discussion in 'Test Zone' started by schooter, Feb 15, 2010.
  1. schooter
    hey, just though I would make a contribution to the site and make a vivid how-to upload and post pics from photobucket... but I dont know how to capture whats on my screen as an image.... help?
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Hi Schooter,
    If your using windows vista or 7 there is a tool in accessories called snipping tool and this makes light work of screen cap.
    If your using windows xp or previous using the printscreen (prt scr) button next to the scroll lock and pause/break keys will capture the screen to the clipboard at which point you open a graphics program and either create a new pic and paste the clipboard into it or look for a create new from clipboard selection.
    There are third party screen cap progs for pre windows vista too. One i've used, freeware, is called gadwin printscreen which works a charm in xp.
    That's the basics, hope it helps!
  3. kcoop99
    kcoop99 Member
    BFE, Nebraska
    fn (function button) on bottom left corner of keypad + prt sc button. Then you can paste to clipboard....typically
  4. mwhite74
    mwhite74 Member
    alt+PrtScn will screen grab only the active application, not the contents of the entire monitor, FYI...
  5. archiebron
    archiebron New Member
    HI,
    you just nedd to press the print screen and then open the paint and paste over it and then save it as image.
  6. Pacocase
    Pacocase Member
    MD
    Everybody here is correct, but I'll sum it up a little. If you're in Win7 or Vista, the snipping tool is useful for selecting specific sections of the screen you want to capture.
    99% of the time, though, Alt+Prnt Scrn will do, since it captures only the current active window and not the whole screen like just pressing Prnt Scrn by itself does.
    From there you can cut and paste directly into documents, or you can open a graphics editor like Paint. (Start>run>mspaint) It is the easiest and most primitive, and it will allow you to easily save the image as a bmp or jpg for uploading.
