HSC33 diaphragm performance video linked
Discussion in 'XJ Technical Chat' started by to the max, Apr 11, 2022.
  1. to the max
    to the max Member
    Akron, Ohio
    does this look ok to you guys?
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Carb #1 looks decent, maybe could be a bit more free. The others, not so much. The way the slides seem to fight your screwdriver, it seems there is some cleaning to be done, not the fault of the diaphragms.
  3. to the max
    to the max Member
    Akron, Ohio
    Everything is super clean. I’m more referring to the rate at which it closes
  4. Huntchuks
    East Rochester, NY
    Sticky opening = sticky closing. Too slow on 2, 3, 4.
  5. to the max
    to the max Member
    Akron, Ohio
    You were right. They needed more cleaned.
    Thank you
