I got caught cleaning... YICS.
Discussion in 'XJ Technical Chat' started by Door dude, Mar 4, 2017.
  1. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    I can't find the right mop to clean the YICS system any suggestions ?
  2. Polock
  3. Door dude
    Im on a hotel wifi that is censored, polock, is there something naughty on that link ? ive got the gun cleaning tool for the big hole, i need what it takes for the small hole's
  4. Polock
    gun links are commonly censored...you need something like a bare welding rod with a point and a 90 bent close to the end and try to poke the little holes on top of the passage. on a 750 the holes are about 3/32, not easy. could you settle for a compressor and a bunch of air?
  5. Door dude
    Okay i can do that. Will a carb cleaner additive do anything ?
  6. Polock
    probably would if you could get it to stay in there awhile BUT there's a o-ring between the jugs and the head that seals those yics holes so carb cleaner might not be a good idea
  7. Door dude
    ok po thanks for the info. And i didn"t mean to rhyme .
  8. Polock
    that's a 3/32 drill bit, 1/8 won't fit. that's where you're pushing any crud to, the hole in the head is about the size of the o-ring id
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    In a hotel room, using Wi-Fi to search "tools to ream holes with". Can't imagine what would trigger the censorship software. PS gotta erase the browser history.
    quebecois59 likes this.
  10. Door dude
    The xj comedy hour starring matti thundrrr. My engine is not apart, is there a way to clean them from inside the tube ?
  11. k-moe
    I never did bother to clean mine. When I had the head off I found that there was just a bare film of carbon on the passages. If you suspect that yours are blocked you can do what Polock suggests, and then run Seafoam in the gas to help clear out any remaining carbon.
    Lightcs1776 likes this.
  12. BigT
    BigT Active Member
    Airville, Pa
    Chacal does sell a specific tool for the job, I believe it has markings to help you find the correct spots. I used it, can't say it made any difference but gave me a little peace of mind.
  13. Door dude
    Ok, thanks guy's for the info. Think i'll just not worry about it. 19,000 mi. i'm probably good to go.
