I'm confused about my forks....
Discussion in 'XJ Technical Chat' started by kontiki, Sep 8, 2008.
  1. kontiki
    kontiki Member
    Columbia, SC
    I've noticed it may be time to replace the fork oil and possibly check air in my forks... they don't bounce as nicely as they once did. The seals appear okay. So... after reading the manual I popped the caps off expecting to see an air valve but all I see is a flat steel disk at the top of each fork!
    Anyone have a clue how to remove these to change the oil or (perish the thought!) add air? Maybe 1980 model doesn't have an air valve !? But there has to be a way to add oil...
  2. MiCarl
    No air valves on the '80-'81.
    Do you have the factory manual? If so ignore the first section which is the supplement for the 82-83 models. It'll mess you up with an '80.
    If you press those steel discs (spring seats) down just a bit you'll see a circlip. It's a lot of fun to dig out :!: It only takes 3 hands. I use a bar clamp with a deep socket to hold the spring seat compressed while I dig the clip out.
    Then, there is a small phillips screw near the bottom of each fork. Pull them and the oil will drain. Put the screws back in after the oil is drained.
    Pour 262ml 10 weight fork oil into the top of each fork. Push the spring seats back in and install the circlip. This is just a bit easier than getting them out.
  3. bill
    bill Active Member
    Raleigh, NC
    Now you tell me :lol: I had to figure that one out last week. The bar clamp and socket works well but I had 4 hands. I had my wife hold the clamp from slipping while I dug those pesky clips out.
  4. Polock
    be ready for a big mess when you take the screws out of the bottom of the forks, have a can and some rags ready
    push the wheel up and down a few times to get all the old oil out, watch out for more mess
    pour in the new oil slowly, work the forks up down with half the oil in them
    add the rest of the oil, work the forks, get the air out
    slide the springs back in slowly
    if theres air trapped in there and you drop the springs in the oil comes flying out
    ask me how i know this :)
  5. schmuckaholic
    California
  6. bigfitz52
    I might add: Be SURE you can actually get the caps/plugs OUT of the forks BEFORE you drain the oil. Mine are horribly rusted in place and I've been working on a "process" to free them up. (Long story.)
  7. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Just a little tip, loosen the top triple tree clamps before you try popping out the caps, otherwise they might seem like they are 'stuck' in place
  8. bigfitz52
    Tried that. They're stuck, but this isn't my thread and I didn't want to hijack it.
  9. switch263
    switch263 Member
    Austin, TX
    My 81 has air valves on the forks, right under the tripletrees.
  10. MiCarl
    Yours isn't a 650 Maxim.
  11. Robert
    ^^^Right you are MiCarl!
  12. switch263
    switch263 Member
    Austin, TX
    touche =) misread the OP
